Engine Size
Good day all,
So i want to know would an 30cc engine with 2hp be enough to fly an aircraft of 20 - 25kg ? Please need some help here.
Thanks in advance.
  • Flight Controller - 15g
    R/C Receiver - 15g
    Silver Blade Frame - 150g
    4x Motors and ESC - 200g
    3S LiPo Battery (1300-1800mah) - 150g
    FPV Camera and Transmitter - 50g
  • Hi Johan,
    The answer is dependent on the airframe you choose. Based on what you have said though, this is marginal power for even  a powered sailplane.
    Given a more "ordinary" planform, I think you'll need 8 hp or more. I have a past design that flew well with 3 hp on a 10kg airframe. It would not hover, but climbed fairly well.
    dennis
    Yes if the wingspan of the aircraft is large enough.
