Hello Everybody,
i have two questions which hopefully somebody can answer:
First question:
- If i have a PC and a TG9x with the ER9x- Ardupilot Firmware, is it possible to connect both the PC (Mission Planner) as well as the Remote Control (TG9x) to the Ardupilot at the same time ?
-> E.g. by running a Cable from the TG9x to the PC and using the same modem ? - In other words, can mavlink be used multipoint ? - Or is it only point to point ? - If so, how would i wire TX and RX ?
Second question:
- Is there a software version for the ER9x which supports also rolling switches ? - I have tried the normal ER9x, but it seems not to support e.g. to use the TRN switch as rolling switch like the SW version from GerardV. - Anyone got an idea ?
I would really highly appreciate an answer on this.
Cheers
Florian
Permalink Reply by Earl on March 18, 2012 at 7:56pm IDK if I said this. I am using the purple APM2 board.
The 57kb problem must be some little timing error. I will try to trace it down.
When I get time I will post the source code for mavlink on the er9x site if it is ok with you.
I will call it er9xMavLink
Now it's back to school Monday. Spring break is over. Hard on a 65yo that went back to school to become an astrophysicist !
Earl
Great Earl,
It work now on APM2 and xbee.
Yes you can put this code on er9x, but it work on ArduCopter, not on ArduPlane.
I am younger than you, only 52 springs :)
Permalink Reply by Earl on March 19, 2012 at 8:38am
Permalink Reply by Earl on March 19, 2012 at 9:24am Yea !! Works with APM2.0 board and version 2.30 of arduplane if you change the baud rate of serial3 to 38400 !
Earl
Permalink Reply by Earl on March 30, 2012 at 9:22pm Tried with Mission Planner 1.1.59 and Ardupilot 2.3.2 works at 38kb good.
Works at 38kb on Arducopter 2.5.3 well also.
I have not checked 57kb lately. I don't know what com library they used to compile the hex code on 2.3.2 or 2.5.3
Hope your around this weekend !
Earl
Permalink Reply by Florian G on March 31, 2012 at 1:03am Hi !
I hope to get this working also with 56 k in the end as i want to use joystick control via MavLink in addition to the remote - so this will likely cause too high latency.
Unfortunately it looks like that i will get only to test this in a few days.
Lets see. Does anybody know where the sources of the GV9x are ? - I could only find hex files - or do you think the problem is only in the APM 2.0 ?
Cheers
Florian
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
314 members
4 members
1292 members
684 members
Powered by
