After installing the module 3dr, one of my ESC burnt.
It was just coincidence or is there some link with the install of this module?
The control wire of the ESC was close to the 3dr module .
Tags:
Permalink Reply by Richard on July 31, 2012 at 12:49pm Either coincidental bad luck or a wire got moved by accident during the installation and shorted out.
It is practically impossible for interference on the ESC signal wire to damage any well-designed ESC, invalid input should be ignored and eventually trigger ESC shutdown if it lasts long enough.
Assuming 'short' wires betwixt ESC and motor no external influence other than overvoltage or short circuit on a wire or motor overcurrent should be able to directly cause them to burn.
Signal and BEC is 5V so main battery +V touching either of those wires will probably kill it (and your receiver/autopilot), and 0V touching a BEC output may reset the ESC. If the motor is running at the time it may burn.
Either way, most ESCs live on the edge of disaster by design as they have minimal heatsinking and expect low duty cycles - intended to run for a few tens of minutes and usually in the draft of the prop.
Permalink Reply by Alexandre Nascimento on July 31, 2012 at 3:07pm I think was a short circuit.
Thank you very much!
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1356 members
54 members
203 members
88 members
24 members
Powered by
