Hi all,
I have one problem with my arducopter that i was not able to solve (after 2 days of testing), and that is ESC erratic behaviour.
First when I apply the power, all motors start turning, and as I advance throttle one motor (rear) starts to glitch. After 2 tries I managed to get it in the air, but for 10 seconds, and the motor suddenly stopped working.
Then I went to this forum, and found out that some connectors were soldered improperly, and rechecked and resoldered all connectors "thick".
After that I had a solid 1 minute flight, and as soon as I thought that I have solved the problem, the motor started to glitch again. But this time more often. Like 8 out of 10 times it wouldn't start at all...
When I switched the ESC (front to rear) then front motor stopped working, so that eliminated power distribution board and motor problems.
The problem was in ESC. It did go a little warmer than the others (but it was the one that powered APM).
 When I connected the motor outputs to oscilloscope i noticed that when i apply throttle that it does not produce standard output, but that it additionally produces off the scale peaks. I checked the others and they have nice constant output.
Anyone had this problem?
Tags: Arducopter, ESC, glitch, problem
I will ask an uninformed question.  Have you individually calibrated the ESC's using just your transmitter, receiver, esc and motor?  I have experienced similar problems when I thought that I had them correctly calibrated when they weren't.  If you have already done so, then I will defer to those with more experience here.  I hope you get it up and flying soon.
Yes. That step I forgot to mention... I did that before I checked with my oscilloscope.
Thank you for trying.
I had a dud ESC in mine - the BEC portion worked, but it did not detect the receiver - replaced it and all works well - I dont think these ESCs are the greatest quality, so a few seem to be DOA or faulty.
- Could also be bad solders- the motor solders are terrible and should be redone - I just redid mine today after the glitching problem. Not sure if solders on the ESC would cause your symptoms.
Yes, once you've checked your solder joints on the ESC-Motor side (wiggle them with power on--careful to avoid the prop!) to see if you get intermittent results and re-calibrated the ESCs, if you're still having trouble with one you should get it replaced.  I'm getting about a 10% failure rate from HobbyKing ESCs, so it does happen.
Thank you guys,
That is what i suspected, but since I was so happy about the flight with my arducopter, and fahpah does not have these spare ESC's In stock, i am a little bit dissapointed. I don't want to buy new set of 4 ESC's from HK so i have to wait :(
Eugen
Eugen,
To eliminate a similar problem I had to replace all the ESC connectors and the motor side connectors and the red ones coming from the ESC and the ones on the power board. After doing all that everything worked well.
Thank you Doug :)
I am running a turnigy plush 18a for the one ESC that popped and it works exactly the same. Seems to be same type ESC will work as well. Ie don't all have to be exact.
I have tried with one 30A I have from Heli, but after calibration it still couldn't fly. It just had more RPMs then the rest.
Maybe if I have 20A then it would work the same?
