Hello there
Got the original J-Drones ESC's an a strange phenomena
when i plug in the LiPO i get a beep beep beep beep ( fast around 3 beeps per second ) from my motors.
I think this means " under Voltage ". My LiPO is fully charged and after a few try's sometimes the beep go away and i can fly....
Got no Ottopilot attached and disabled all Battery monitoring settings in the setup.
any advice is highly appreciated
Tags: ESC
Does it happen always or only when flying outside? Some ESCs are suspectible to cold - if you let them be for a while they warm a little, holding them in hand helps. This signal is usually that there is incorrect signal (too low/high pwm). Try recalibrating your radio with a lower or higher throttle trim (and reset it after calibration), or calibrate it when cold.
thank's a lot !
did just the RC Calibration again and it works fine.
The temperature issue i had as well when we had -20C
regards
