Is there a way to create a GPX file from and image that has gps data in its Exif
I am trying to use Palentier to overlay images onto Google earth but it requires you to load the jpg image and gpx track data in order to match it up and then export as a KMZ to google earth.
I don't have separate track data as the gps is in the camera and its data is in the Exif of the image.
If I cannot use Palentier what can I use to send the image to Google earth as an overlay?
Any help would be great thanks.
Tags:
Permalink Reply by RN on December 31, 2012 at 6:24pm Whats the source of the Exif location data in the photo?
While it would not be very hard to convert the exif data to a single point in a gpx file, it will not be enough for Palentier to overlay the image.
The reason they need a GPX file is to get the telemetry of your UAV to calculate the proper position of the picture. I wouldn't be surprised if they also need the azimuth and elevation of the camera relative to the UAV to get an accurate calculation.
Permalink Reply by JP on January 3, 2013 at 4:28am One thing you need for Palentier is a compass heading.. this is required so each image can be rotated or oriented properly on the ground. If you build a gpx file from the logs, make sure to include the <compass> tag in your gpx option to work with Palentier.
Permalink Reply by RN on January 7, 2013 at 11:26am It should need
UAV:
Latitude
Longitude
Altitude
Pitch
Roll
Heading
Camera Elevation angle relative to UAV
Camera Heading angle relative to UAV
Permalink Reply by Bret C on March 11, 2013 at 3:50am JP:
I see that my recent GPX files created from the Mission Planner, Telemetry Logs, Tlog>Kml or Graph, Create KML +GPX did not include the compass heading.
Where / how do we "make sure to include the <compass> tag in your gpx option to work with Palentier?"
Thank you.
Bret C
Permalink Reply by Bret C on March 12, 2013 at 5:04am No feedback on this post so I reposted this question here
Permalink Reply by Richard Brown on April 22, 2013 at 3:18pm Bret,
I have to go into Notepad, open the GPX file, and do a "replace" on "course" to change it to "Compass".
Then Palentier will recognize heading in the GPX file.
Yes, it would be nice if MP would do this for us in the Telemetry GPX file.
I'm still having issues with images that are lower than the avg height of the mission. Seems like Palentier is not really using the altitude info properly to calculate scale of overlay. And compass is still not orienting correctly it seems. Lot of manual tweaking.
Exiftool will create gpx track files from a group of images, see 'inverse geotagging" here:
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.203 members
24 members
207 members
58 members
1355 members
Powered by
