F450 Case
I have a dji f450 and am have been looking for a case for transportation, but have not been able to find one to fit it.  Does anyone have any ideas for a transportation case?
Thanks!
  • Brian, I've been doing the same as well.
    This is the best that I have found but I haven't ordered it yet.
    Here's the content from my post from another board:
    What do y'all think about using this shell for a carry case?
    http://www.carrycasesplus.com/blow-mold ... p-990.html
    I think I can get the BP-990-E (empty) case and then find much cheaper foam inserts.
    I've measured my arms on my F450 to be < 14.5" and the interior of this case at 14.625" would allow it to fit but might not allow for foam between the arm ends and the side wall of the case, which I'm not that concerned about because I am SO TIRED OF LOOKING for cheap cases!
    The widest edge of the arms is exactly 6.5" off the ground which would put them about .5" above the top edge of the case base. and might slightly interfere with closing.
    I guess I will continue to look but keep this one in mind.
    Any other product suggestions in the < $100 range?
