I have Mission Planner 1.2.92 installed on a windows XP service pack 3 machine with .Net4 installed. When I connect my APM2.6 I am unable to upload the Arducopter firmware. I get the following error.
Failed to download new firmware: System.Runtime.InteropServices.COMException (0x8007042C):
The dependency service or group failed to start. (Exception from HRESULT:0x8007042C) at System.Management.ThreadDispatch.Start()
At System.Management.ManagementScope.Initialize()
At System.Management.ManagementObjectSearcher.Initialize()
At System.Management.ManagementObjectSearcher.Get()
At MissionPlanner.Arduino.BoardDetect.DetectBoard(String port) in c:\Users\hog\Documents\Visual Studio 2010\Projects\ArdupilotMega\ArdupilotMega\Arduino\BoardDetect.cs:line 41
At MissionPlanner.Utilities.Firmware.update(String comport, software temp, String historyhash) in c:\ \Users\hog\Documents\Visual Studio 2010\Projects\ArdupilotMega\ArdupilotMega\Utilitites\Firmware.cs:line 344
I am able to see the board in windows device manager as Mega 2560 connect to port 5. I can also connect to the APM with Mavlink and get real time flight data back.This works when I select port 5 or it even works when i use auto select. I also see it connected via the terminal.
The problem is I continually get an error when I try to upload the firmware. What am I missing? Any guidance would be greatly appreciated!
Bonjour ,
I have the same problem that you had before , what do you mean by windows services
Greeting from France
Patrice
have you disabled system services?
