I posted this on another topic but I should have specified it more directly in the proper topic here. My application requires a lot of heli related aspects and arducopter covers them. However, what I need is what was suggested to me in the other topic and that was FBW-A flight mode. I have only see it in the arduplane wiki, I have not seen it in the arducopter wiki let alone the heli one. I have very very little knowledge of coding but if it requires an insert somewhere I could try it with some help. So with all that said is FBW-A in arducopter?
Tags:
Permalink Reply by gearwolf on June 23, 2012 at 8:30pm I found the mode that is in arducopter similar to this but how do I add user defined modes like ROLL_PITCH_STABLE from the wiki? This mode should be like FBW-A in arduplane where the stick angle makes the aircraft go at an angle and not at a rate, right?. I see there are a couple of lines on how to do this but I'm at a loss as to where to start. Do I modify the config file? if so which one. Do I copy and paste code into someplace? Any help with this would be much appreciated.
I think what you're looking for is already implemented. Stabilize mode maps a roll/pitch angle to the stick position. Full stick movement gives you 45° attitude. Center stick makes it center. Simple as that. This is the most common mode being flown, works quite well.
Permalink Reply by gearwolf on June 25, 2012 at 6:37am That sounds perfect. Sorry for this simple question. When I looked at the wiki it looked like I needed to add code into the config file and when I looked at the file it said don't touch. I need this to transition a heli to and from horizontal to maintaining a constant 15 degrees of pitch in the second mode which if this all works I can just add that into a mix. Thank you for your help.
What exactly are you working on?
Interesting. How does an autogyro take off vertically?
Permalink Reply by Aaron on June 25, 2012 at 9:37am They can't, nor can they hover.. What he is proposing is a Heli / Autogyro transition similar to the Heli / Fixed wing of the V-22 Osprey, hence the 15deg cg shift..
Correct me if I am wrong gearwolf..
So... is this a helicopter (with a powered rotor) and then a pusher prop?
Like the Cheyenne?
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1286 members
87 members
39 members
24 members
5 members
Powered by
