Hello All,
This is going to be my first experience building a quadcopter (for that matter an R/C flyer). I have so far ordered the following items:
  1. 3DR quadcopter frame.
  2. 850Kv motor + 20A ESC + props from jDrones (3DR did not have any of these in stock for almost a month)
  3. Aurora 9 transmitter + Optima 9 rcvr
  4. I am waiting for the APM2 board to be back in stock.
I have been through this forum for a long time now (2+ mo) reading every single post, read the Wiki on the arducopter, looked at a lot of forums, videos, instructions etc. There are some questions that I still have and would appreciate if one of you can enlighten me on them.
1. There has been some mention about the Aurora 9 having detention point on it's sticks and this could pose a problem for the quad control. Other than this, is there anything that I need to watch out for/ modify to make this work with quadcopter.
2. I have read in numerous places that a 3000mAh Lithium-polymer should be a good starting choice. Is there a specific brand that is recommended. Any specific reason between choosing Turnigy nano-tech vs regular or Zippy vs zippy compact (all these are at HobbyKing). What would be a better charger to select?
These are my boundaries when it comes to making a decision on purchasing the batteries / chargers.
Yes price is a factor but it is also true that if you pay peanuts, you get monkeys. So I don't want something that will last me only a few charge cylces, perform only under a small windows of temperature conditions. But I don't want something that is the latest and greatest out there. Somewhere in the middle for someone who is going to stay in the field of R/C for a while (couple of years as I see it today)
I want a good, reliable charger. I read in one of the forum posts that iMax B6 is not so good and iCharger 106B is a better one. Is there any reason not to consider HobbyKing's ECO4-S?
Forgot to ask the most annoying question of all. Given all this and a suggested LiPo, how much of a flight time can I expect out of this quad?
Appreciate if one of you could help me clear my questions and I really do hope APM2 comes back in stock soooooon.
Tags: 101, Basic, arducopter, batteries, chargers, questions
1) You probably won't even notice the Aurora9 issue if it does exist on your radio.  If you do, send it back under warranty or apply a fix http://www.rcmodelreviews.com/aurora9issues.shtml
2) I like the Zippy 5000mah 3s 20c batteries for $27.  I've abused the heck out of them and they still fully charge.  The nano-tech are just heavier for your purpose.  Higher c rating comes with a weight penalty.  The 20c doesn't even get warm.  I regularly fly with the same motors you are using and (2) 5000mah batteries.  It is a little sluggish, but stays in the air for 25mins.  I looked at all of the battery options yesterday and ended up ordering some more of the same Zippys.
3) Charger.  The eco4-s is designed to slow charge 4 batteries at the same time.  It will only charge a 3s at 4.5 amps max.  You don't need that.  You want to charge one or two batteries fast.  I have the HobbyKing EC06 and it will charge one 3s at 10amps.  That will fill a 5000mah battery in 30mins.
http://www.hobbyking.com/hobbyking/store/__12105__HobbyKing_ECO6_10...
 I usually use a parallel charging board so I can charge (2) 5000 mah batteries at the same time for convenience.  They sell them with most types of connectors.
http://www.hobbyking.com/hobbyking/store/__15237__Parallel_charging...
Ah.. the RCModel reviews. I have been waiting for him to post his review of the Aurora 9. :)
Also as I see it, I do need to buy a power supply for my chargers. Is there nay model that can work with an 110 AC (as I am here in the US?). I just want to lessen the count of equipment on the chargers unless there a good reason to have a separate power supply!
Thanks for your quick reply.
All of them I have seen require a dc power supply.
Of course, you can just attach it to directly to your car and buy a power supply later.  You'll end up doing this when charging in the field anyway.
Thanks Arashi, I finally got my components except for the "Great APM2.0". The only deviation was that I got a Turnigy A-6-10 200W as opposed to the HK model since it was out of stock.
Here is a comparison of prices that I did as I bought my stuff (Assuming it will help other newbies).
Yes, I did pay a lot in terms of shipping but when I was buying stuff I was assuming that APM 2.0 would be back in stock quickly and 3DR was out of stock with their motors.
