I have been reading a lot of material on this forum as well as others and I am confused as to which hardware to select.
I have a fixed wing airframe and I want to set-up an autopilot to:
- have fun
- watch FPV while the wing flies itself
- do some mapping
- and probably for some agricultural survey (NIR pictures of crops basically although at a later stage it would be fun to do some cattle counting on board... but this is way above my skill level)
I have looked at the following material:
- Pixhawk but I find it too big and I remain curious about the pixhawk 2
- Dropix, which is a French pixhawk but smaller and with easier connectors...
- VR micro brain which is an Italian version of the pixhawk, even smaller
- Brainfpv which runs Taulabs software and has an OSD included
- Navio+ which runs on top of Raspberry PI 2 and I worried it is going to be too complicated for me
- and finally the Lisa/s but my frame is big enough to have something larger
I want to be able to have an altitude sensor and a speed sensor and maybe a range finder for proper landing and/or terrain following.
What should I do???? I am lost.
Thanks so much for your help.
Best - Silaxe
@Silaxe,
If you want positional accuracy I would go with the Pixhawk as you can enable the EKF function which you cannot do with the APM.
TCIII AVD
Really, nobody has a piece of advice for me?
Please?
Thank you.
