Fixed Wing for Bat monitoring
Hi everybody,
I'm looking for an autonomous and ready-to-fly fixed UAV to install a sensor with 17 cm long, 9,5 cm large and 2,5 cm high (it's the green component in the picture).
The small microphone needs to be outside the plane. It’s an unidirectional microphone, so we need to set it horizontally outside the plane.
The flight time should be superior to 30 minutes, if possible.
I would appreciate your knowledge and expertise to recommend the ideal UAV with these specs.
Thanks !!
3691180289?profile=original
  • Hi patrício, Alexandre,
    My sugestion is the E384LR UAV, is a really great UAV plataform, with best possibilities for autonomous flights, mapping etc, with 100min flight autonomy and up to 1kg of payload capacity into room space.
    The airframe was based in Skywalker 1900mm airplane, an old friend of MILIONS FPV PILOTS around the world.
    Jeff Taylor, the Event38 founder, was part of staff of 3DRobotics, he is a lot experiented.
    Just take a look: www.event38.com
    Good luck!
