Flaps not working on mode RC
Hi, i have a Skywalker aircraft with the following setup:
  • Arduplane Firmware V.2.74b
  • Ublox GPS
  • Power module for APM
  • 5800 mah battery
  • 40A SBEC ESC from hobbyking
  • FR sky receiver (8 ch) 2.4 ghz
  • 9Cap transmitter
My skywalker is equipped with flaps, and i need to use them in flight, but (for the moment) i want to use the flaps in manual mode, not in auto mode.
Now, i´ve seen that i can use the flaps in manual mode by asigning them with the RC_function. I tried with the RC_6 on the 2 value, and there is no output on the servo when i hit the flap switch on my transmitter. The flaps are asign on the 6th channel on my transmitter
I already set the min, max and trim pwm values and still nothing.
PS: i plotted the ch6in and ch6out, and the ch6in does change along with the changes in the transmitter, however the output remains the same.
Attatched you will find my .param file
Skw_02.param
  • You still need to set the RC_function to flaps_auto, otherwise it wont work.
    If you keep all other flap related settings to default flaps will work in manual/stabilise/fbwa with your transmitter's switch, and in auto they won't deploy.
    I don't know what the reason is but I had the same issue when I tried to setup flaps for the first time.
    a tip: bypass the APM flap channel (connect flaps servos directly to receiver) just to test if your transmitter is set right.
