Hello Everyone,
i have implemented a rolling switch for the following flight modes in my RC.
Currently, i have the following modes set:
Stab
Alt-H
Loiter
Pos-H
My remote also generates just the right signals, but the APM shows me Stabilize, even the display says e.g. Loiter.
Anyone got an idea what is wrong here ?
I attach a picture to show the inconsistency between the settings and the actual flight mode set.
Even the PWM is in the right range and this mode is set to Loiter (1361-1490: actual value 1431), the current mode actually says stabilize everywhere, even i would expect Loiter.
Is this a software bug ?
Cheers
Florian
Tags:
Permalink Reply by Florian G on April 28, 2012 at 1:43pm PS: I have of course pressed save modes before, the picture is a bit misleading. The problem shows up even save modes has been pressed before.
Permalink Reply by Florian G on April 29, 2012 at 1:15pm Hello ! Does not anybody know what this could be ?
If the other flight modes do not work, i think this could be a quite important software bug.
Has anyone experienced the same, not to be able to change modes outside stabilize or alt-h ?
Cheers
Florian
Permalink Reply by Wesley Chuen on April 29, 2012 at 1:19pm
Permalink Reply by Florian G on April 29, 2012 at 2:09pm Ok - this could explain it !
I will try this as soon as possible (e.g. tomorrow evening).
Cheers
Florian
Permalink Reply by Florian G on May 1, 2012 at 3:43pm Ok - i can confirm once the APM has GPS lock and it potentially hovering, it is possible to switch flight modes. - Unfortunately, i have now the next issue with the Position hold always tilting to one side.. - http://diydrones.com/forum/topics/position-hold-mode-moving-aircraf...
Slowly, i am working my way through the APM..
Cheers
Florian
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.203 members
54 members
88 members
24 members
720 members
Powered by
