For Sale: X8+ w/ Hardshell Case $1300
This X8+ was briefly used as a mapping platform and has flown only a handful of missions. Like new condition. Extra props are included but no ground station radio. Originally paid over $1700. Asking for $1300 obo. Buyer pays shipping
Includes
  • Controller with live on-screen flight data
  • Flight battery and charger
  • Operation Manual and Flight Checklist
Specs:
  • Battery: 4S 14.8V 10,000 mAh 10C
  • Battery Dimensions: 6.6 in x 2.6 in x 1.4 in (16.7 cm x 6.5 cm x 3.5 cm)
  • Battery Weight: 803 g
  • Autopilot hardware: Pixhawk v2.4.5
  • Autopilot firmware: ArduCopter 3.2
  • GPS: 3DR u-blox GPS with Compass (LEA-6H module, 5 Hz update)
  • Motors: SunnySky V2216-12 KV800 II (The images above show conical nuts; X8+ ships with hex nuts.)
  • Controller: FlySky FS-TH9X with FrSky telemetry module
  • Frame Type: X
  • Propellers: APC Propeller 11x4.7 SF (10), APC Propeller 11x4.7 SFP (9)
  • Vehicle Dimensions: 13.7 in x 20.1 in x 11.8 in (35 cm x 51 cm x 20 cm)
  • Payload Capacity: 800 g (1.7 lbs). Additional payload possible up to over 1kg with reduced flight time.
  • Vehicle Weight with Battery: 2.56 kg (5.6 lbs)
  • Maximum Estimated Flight Time: 15 min
X8+ Case
This sturdy, wheeled black case is built to accommodate a 2014 X8 with all the fixings. No need to remove the gimbal, this case will get you out on the road and up in the sky in no time. X8+ requires the propellers to be removed before fitting into the case.
3691224338?profile=original3691224281?profile=original
  • Is this still available? I'm very interested.
