FPV Mini Camera
I need to setup 2 small cameras with different lens in the nose with pan tilt servo gimbal, I found I can only fit the nano cameras to get 220 degree pan and 100 degree tilt. Here is the camera, have anyone tried it: http://hobbywireless.com/mini-fpv-ca...al-p-2155.html
is it a good camera?
Nano Camera 750 PAL
This 750 line camera comes with a handful of awesome features, making your videos better than ever by giving you the access to fine tune and optimize your videos.
With the latest Sony® EXview Super HAD ll CCD image sensor, it will provide astonishing and ultra sharp pictures.
You will find very important features for FPV like the BLC (Backlight Compensation), WDR (Wide Dynamic Range), DNR (Digital Noise Reduction), and OSD (On Screen Display).
Specifications:
  1. Signal System:NTSC
  2. Image Sensor:1/3” 960H SONY ExView HAD CCD II
  3. Scanning System:2:1 Interlace
  4. Horizontal Resolution:750TV Lines
  5. Scanning Frequency (H):15.734 KHz
  6. Scanning Frequency (V):59.94 Hz
  7. Total Pixels (H x V):1020 x 508
  8. Effective Pixels (H x V):976 x 494
  9. Synchronization:Internal
  10. Lens:2.97, 3.6, 4.3, 6.0, 8.0, 16 mm
  11. Lens Type:Fixed Board Lens
  12. S/N:More than 50dB (AGC: Off, DNR: On)
  13. Gamma:r = 0.45
  14. Min. Illumination:0.15 Lux
  15. Shutter Speed:1/60 ~ 1/100,000 sec
  16. Day & Night:Digital Day & Night
  17. Day & Night Function:Auto, Color, B/W
  18. Video Output Level:1 Vp-p Composite (75 Ω)
  19. On-Screen Display (OSD):Built-in (Inner Key / Joystick)
  20. BLC:Off, BLC, HLC
  21. DNR:2D DNR
  22. ATR:On / Off (Level Adjustable)
  23. White Balance:ATW, Push, User1, User2, Anti CR, Manual, Push-lock
  24. Privacy Masking:4 Zones
  25. Mirror:On / Off
  26. Motion Detection:4 Zones
  27. Other Functions:Brightness, Contrast, Sharpness, HUE, Gain
  28. Language Options:English, Japanese, German, Russian, Portuguese, Spanish, Chinese
  29. Operating Temperature:14 °F ~ 122 °F (-10 °C ~ 50 °C)
  30. Storage Temperature:-4 °F ~ 140 °F  (-20 °C ~ 60 °C)
  31. Humidity:Less than 80% RH
  32. Power Supply:DC 12V (±10%), Max 70mA
  33. Dimension:0.88 x 0.9 inch (22.4 x 23 mm)
  34. Weight:0.17 lbs (76 g)
