I had an idea about building a gas powered quad. It would be powered by some of the new small 4-stroke engines like the honda gx-35.
I know what you're thinking... gas engines don't respond fast enough. But, everyone bases this on using the throttle and carb to control the power output. My idea is that in addition to the throttle you could use a microprocessor controlled CDI ignition to control the power.
With a microprocessor ignition you could immediately cut or reduce power output by skipping a spark for super quick power reduction and you could also retard the spark for a smoother, but still quick reduction.
At say 3000 RPM (typical) you could reduce power within 1/3000 of a sec by skipping a spark, or every other spark for a quarter sec or something of that nature. The throttle could also participate, but the spark control would be immediate.
I'm curious how a gas quad like this would perform. A Honda GX-35 puts out about 1.5 hp, and many sources say it easily turns a 20x8 prop at around 3000 RPM.
Would that be too large for practical use in typical applications? Each engine would be about 1.5 hp @ around 8 pounds (very lightly modified). That would be 6 hp @ ~32 pounds. I've also read that when the flywheel/magneto (using CDI) and clutch are stripped they can come in under 6 lbs. That would be ~6 hp @ 24 lbs.
I'd like to know if this is new territory or if someone has already tried this and what their results are. I haven't been able to find anything of the sort, so maybe it's a truly new idea.
Tags:
Permalink Reply by Jake Stew on May 21, 2012 at 11:58am And just like that $20 million dollars worth of taxpayer money is gone.
Somebody has to be the Nervous Nellie, it may as well be me this time!
Be careful with the 20 inch blades, so you don't end up like this guy... we certainly don't want to lose you!
http://www.abc.net.au/news/2011-08-03/nz-man-decapitated-by-homemad...
Permalink Reply by Jake Stew on May 23, 2012 at 4:23pm How can you be decapitated by a hovercraft? The blades are underneath the whole structure and protected by the floor and a large rubber skirt.
I can see losing a hand, but decapitated? He might be a candidate for a Darwin award.
I've got no other knowledge of the case, but I'm guessing it may have been the forward motion propeller. You could imagine a home-brew unit not having a cowling.
Permalink Reply by Jake Stew on August 1, 2012 at 12:38pm I'm working on getting a CDI design going with the sophisticated capabilities discussed above...
http://www.rcuniverse.com/forum/m_11163300/tm.htm
A two-stroke engine running at 6000 RPM should provide control opportunities at 100hz. A 4-stroke would only have 50hz, but given an air-frame that was designed to be naturally stable (lower CG) it might also work.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.7 members
87 members
131 members
47 members
51 members
Powered by
