My APM connects to arupilot mega board but sometime after connecting when I click on the configuration tab in mission planner, I get a dialog pop-up which says you're missing some dll's. please extract the zip file somewhere or use the update feature from the menu. I have the latest mission planner installed on my wondows XP running desktop, but I am trying to run the arducopter v 2_1_1_r6 +JLN mode to simulate it with xplane, and I am still not getting it right.
Please help!!
Tags:
the latest plannre is 1.1.83. 1.1.82 had a problem
Permalink Reply by Hindole Dutta on May 8, 2012 at 8:40pm Yes I updated but it again happens. Also I cannot get the arducopter fly, I don't know why, I have tried doing everything as given (http://code.google.com/p/ardupilotdev/wiki/ArduCopter) the signals are being received by xplane(as I can see in the network and connections menu of xplane)but just as soon as I connect the APM , the throttle becomes zero and it finally crashes... can't figure out why.
Any suggestions please...
can you post a screen shot of he error, so i can see why its erroring
Permalink Reply by Hindole Dutta on May 10, 2012 at 11:35pm can you please upload ardupilotplanner.log. in your planner directory
Permalink Reply by Hindole Dutta on May 11, 2012 at 2:59am here is the file .. I also attached tlog, don't know which one will be helpful.
Thanks.
the log is the right one, but idealy i need it just after the error occurs, as the log you gave me just shows uploading a firmware.
Permalink Reply by Hindole Dutta on May 11, 2012 at 3:37am Have a look they are of that time..
i just want the ardupilotplanner one.
Permalink Reply by Hindole Dutta on May 11, 2012 at 4:01am These are the other two log files for today... has to be in it i gues..
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
184 members
1290 members
11 members
182 members
Powered by
