I have some questions, but first let me tell you what I have done so far. I have my arducopter assembled, all ESC’s calibrated with the following calibration:
ESC Tower Pro w25 settings Brake-off, Battery type-Li-Poly, Cutoff Mode-Soft, Cutoff Threshold-Medium-High, Start Mode-Normal, Timing-Medium.
Motor-Turnigy 2217 20turn 860kv 22A Outrunner Motor spacing is about 51cm
APM and IMU Fatubu T6XH radio with 4500mAh battery.
My questions are:
Are the ESC setting correct for theses motors and application?
What mode should I start off with to try to get it in the air for the first time?
What PID settings to start off with?
Thanks for any help,
Scott Quartochi
Tags:
Permalink Reply by Scott Quartochi on August 20, 2010 at 6:08pm
Permalink Reply by Scott Quartochi on August 9, 2010 at 4:24am
Permalink Reply by Kevin Vertucio on August 9, 2010 at 5:21am
Permalink Reply by Jerry Chapman on August 9, 2010 at 5:46am
Permalink Reply by Scott Quartochi on August 10, 2010 at 6:10am
Permalink Reply by Kevin Vertucio on August 10, 2010 at 7:30am
Permalink Reply by Kevin Vertucio on August 10, 2010 at 8:03am
Permalink Reply by Scott Quartochi on August 10, 2010 at 1:53pm
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.133 members
1298 members
51 members
249 members
106 members
Powered by
