Getting Started with ArduPilot in an RC Truck
Hello,
For those of you that have successfully used the ArduPilot in an RC truck or car, have you used the basic ArduPilot 1.0 code and, if so, was it heavily modified from the code used to control airplanes? I'm just getting started on controlling my crawler with ArduPilot and I need some suggestions from those of you that have done this on how to get started. First off, how would one modify the code to make the maximum speed of the ESC very slow? I want to try playing around with the navigation settings, but I want to be able to walk along side the car as it's navigating. Thanks for any suggestions that you might have.
In the mean time, I have been experimenting with simply connecting a dummy servo to Ardupilot OUT 1 and manually controlling the throttle, but have had some difficulty obtaining a GPS lock. The MUX and POWER lights are on, and the LED on the GPS module itself is on, but the GPS LOCK light remains off and the STAT light just turns off after waiting for a while. What is the normal amount of time to wait for a GPS lock?
Thanks,
barkerzd
barkerzd
Tags: car, crawler, gps, truck
Is the LED on the GPS solid on or blinking? If it's not blinking, you don't have a lock. Indoors, you may never get a GPS lock, and even in the best of times it can take a few minutes. Outdoors, you should get a lock within a minute or two.
Yes, the LED on the GPS module is blinking, which seems good, as I understand it. The GPS LOCK LED on the ArduPilot board is off however, which is what's confusing me.
That's not right--you've got something loaded wrong.
Please confirm that you have it set up exactly like the diagram (except without the FMA Co-Pilot and ailerons and elevator servos, of course).
Also, with ArduPilot running and the FTDI cable connected, what do you see in the Arduino IDE's serial monitor (don't forget to set the baud to 4800)?
Finally, is the MUX LED responding properly to turning the CTRL channel toggle on and off?
Hi Chris,
Sorry for taking so long to get back to you; I've had a pretty busy week and haven't had much time to play around with my AP project until now.
My setup differs from the diagram only in that the throttle and steering are setup to be Channel 2 and Channel 1 respectively on my Futaba RC car receiver, not Channel 3 (throttle) and Channel 4 (rudder) as you mention in the ArduPilot Assembly Instructions post. The entire setup is as follows: the steering servo is connected to AP OUT 2, there is a dummy servo in place of my ESC connected to AP OUT 1, the AP IN 1 is connected to Channel 3 on my RX, and the AP IN 2 is connected to Channel 1 on my RX (not Channel 4 as in the diagram). My ESC is connected directly into Channel 2 of my RX so I can manually control the throttle. I have AP CTRL connected to Channel 4 on my RX, but I'm not sure if this is what's causing me trouble. This has confused me so far since my TX/RX setup (Futaba T4GWD-AM) doesn't have a toggle switch. To remedy this, I've tried ignoring the MUX through the software as you suggested in a previous post. Are there any ways that I might be able to achieve this through some sort of hardware solution?
So after uploading the modified sketch files (to ignore MUX), I placed the entire RC car setup near a window for ~10 min. to get a GPS signal, which is achieved in ~5 min. as indicated by the blinking LED on the GPS module (but still no blue GPS LOCK LED). During the entire time the AP is searching for a GPS signal, the MUX, STAT, and MODE lights are flickering and the steering and dummy throttle servos are twitching. This behavior continues even after the red LED on the GPS module blinks to indicate a GPS signal lock. Looking at the serial monitor during this time shows long periods where only "Waiting for fix position" is displayed followed by long periods where only "ArduPilot!!!" is displayed. Occasionally, some data like "Mot: 0 Yaw: 60 Alt:0 Crs: 0 Dis: 36928 Des: 180" will be displayed, but only very briefly on one line. After ~15 minutes of a blinking GPS module LED, but no AP GPS LOCK LED or meaningful serial monitor data, I turned the entire unit off.
Finally, is there any way to limit the maximum speed of my ESC through the software? I have tried a few things, but nothing has worked so far. If I could do this, I could have the car navigating very slowly on its own, without me working the throttle on my TX. This would also simplify my very confusing setup as described above, I think.
Does any of this sound like it might be causing a problem? What changes might I need to make to my wiring to and from the AP board? Thanks again so much for your help.
ArduPilot was not set up to be used without an input on the CTRL channel. But there is a way to solder a wire from a spare digital pin to the TMISO pin and tell the software to set it high, simulating the MUX turning on. Consult the schematic for more.
This would be connecting the pin labeled "D6" on the board with the signal pin on the CTRL channel, correct? Then I would just need to modify the ArduPilot code as GhostRider did in this post?
By the way, has anyone that you know of tried controlling the maximum speed of their ESC using the AP code? That's my next problem to tackle after this one...
Thanks again for your help.
Correct.
OK, I'll give it a try. Thanks.
