Gimbal Setup
Anyone running a gimbal on their helicopter?
Curious if someone found the best route for taking vibration out of the camera while in flight and in a hover?
Care to share?
  • Here are a few samples of different setups I have on my 700 Trex.
    1: Fixed shock mount
    2: 2 axis cheap gimbal
    3: Tarot 2D Gimbal
    https://www.youtube.com/watch?v=LSaFcFgp7TY
    https://www.youtube.com/watch?v=g5CfLp3WO7A
    • UAS,  Joe Nall looked good.  Gopro?  Headspeed?  Any neutral density filter used?
      David R. Boulanger
      • No Filter used. Yes GoPro, 1230RPM on the head.
        Joe
  • Sean,
    I'm using a tarot 2D and a Hero 3 Black.  Everything works pretty well.  I had to find a good headspeed that didn't cause a vibration issue.  Running 1550 RPM all is jello free.
    David R. Boulanger
    • I am pretty set with my head speed which is right around 1150 RPMs. I need a certain amount of pitch for the weight I am running.  Right now I have a vertical bounce in my video from the blades swinging by. I need to figure out the frequency of the AC to figure out what isolators will work with my setup.
      I am using a Arris 3-axis gimbal which is really nice.
      http://www.hobby-wing.com/arris-zhaoyun-3-axis-brushless-gimbal.html
      • Is it vertical jello or just a sharp vertical movement up and down.
        David R. Boulanger
        • Sharp vertical up and down.
          • Sean,
            I had that problem when my camera when it was hard mounted to my frame.  Once I put the gimbal on it the problem was solved.  I've got a 3 axis gimbal being delivered tomorrow that will hopefully take care of the yaw movement I have not been able to get rid of with PID tuning.  I think its my governor tuning that is causing the problem and will continue to play with that.
            David R. Boulanger
