Hello again all.
I've been messing around with loiter abit after flying our DWAD8 octo for a while now (over 350 flights, not a single issue)
Loiter with the baro seems ok, jumpy and keep circle about 3-4m, with sonar it just sits there, about 1-2m which i think is the best one can expect from gps hold.
Heres a short clip i shot yesterday to show you.
Question, Chris, I saw that there will be optic flow in .50 ? How exactly does this work, what is required and how would it improve hold ?
Thanks!
Duran - Knysna - South Africa.
Tags:
Nifty video.
re the optical flow, at the moment we're mixing the position from the gps with the speed from the optical flow. It's still a work in progress so that method may change. Another possible method may be to use the optical flow for both position and speed but only when you're within a certain range (like 1 or 2 meters) of the desired target, the rest of the time you rely on gps only.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
1276 members
179 members
57 members
183 members
Powered by
