GPS Live Location APM2
Hi Guys iv looked and looked, so apologies if this has appeared else where.
With telemetry and GPS locked in I can see my quad while it is on the ground next to me and it drifts around very slightly as the GPS lock drifts so I know it must be updating. However when i fly only a few meters away the new location isn't displayed on the APM2 it just seems to be sat still.
I get all other information back, virtual horizon etc.
Do any of you know what the problem might be? Im sure it is simple!
Rob Wells
    There's an Auto Pan check box at the bottom of the main map, does checking that help?
    • I have been using the APM2, is the Mission Planner more suitable? I will try  this shortly
      • That dosent seem to be the issue as i tried it in the Mission Planner with the Pan check box ticked and not ticked. In both programs it would occasionally pick up location when a distance away but it seems to be a one off burst of information randomly. Never consistent. I wonder if the telemetry cant handle the data load? Would better aerial help?
          The other thing to check in Mission Planner is the telemetry rates: Config/Tuning > Planner screen - position should not be 0
