Im researching GPS status and would like to graph it after missions. In Telemetry Logs - Graph Log I cant find hdop among graphable parameters.
Also no hdop if i convert to CSV file.
However, under the map view if I go Tuning --> Double Click on graph legend --> I find gpshdop in the available parameters.
Any way to check hdop from log files?
Tags:
IS this for a tlog or a log?
Permalink Reply by Jon von Weymarn on July 28, 2012 at 1:32am look under
gps_raw_int
uint16_t eph; ///< GPS HDOP horizontal dilution of position
Permalink Reply by Jon von Weymarn on July 30, 2012 at 12:14pm Yeah there it is! Thanks!
Permalink Reply by Jon von Weymarn on August 3, 2012 at 12:29pm To answer my own question if someone else needs this info...
Other logs are for example the onboard logs which are enabled via CLI (logs --> Enable XXX)
More about these at http://code.google.com/p/arducopter/wiki/AC2_Datalogging
Permalink Reply by Daniel Portillo on August 9, 2012 at 4:44am Hi, this is some offtopic, do you know what HDOP value is acceptable for fly?, I can't find this info, thanks
Permalink Reply by Jon von Weymarn on August 9, 2012 at 4:57am I am not completely sure so someone correct me if Im wrong:
HDOP alone if not enough to decide if you have a good signal. You also need to take into account Sat Count.
Best I've seen is 11 sats with a HDOP of 78. I fly in Finland so I'm quite high up on this planet we call home. Smarter people have told me that GPS does not work as well here as somewhere closer to the equator.
Permalink Reply by Daniel Portillo on August 9, 2012 at 5:13am Ok, thaks. I think that this is a very important safely parametrer that may be in wiki First-time flying checklist.
Permalink Reply by Jon von Weymarn on August 9, 2012 at 5:25am I agree.GPS (and Sonar) interference would also be valuable in the assembly wiki. My first GPS placement was close to my telemerty Xbee which resulted in some GPS jumps. Moved GPS further and solved it.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1355 members
203 members
24 members
207 members
58 members
Powered by
