Anyone knows of a device that can send an HDMI signal to the ground. Most up to date DSLR cameras now have a HDMI output and not an AV output anymore. One can use a converter to change the HDMI to AV but that adds another 220 grams of weight and the AV signal is not very good.
Tags:
Permalink Reply by Gerry Mostert on March 13, 2012 at 3:32am Yeah, we don't have a lot of Hotspots for Wi-Fi
Permalink Reply by Jaan Kronberg on March 13, 2012 at 5:37am you can make wifi connection from your mac or pc directly to teradek, without need for any "hotspot"
edit: i am not saying teradek is best solution nor am i anyhow affiliated to them, but to me so far it seems to be the best solution - weight, energy consumption and range-wise. and i haven't seen anything that would match the functionality for same price..
http://sr-systems.de/content.php?show=H264-Encoder&lng=eng&...
this is hdmi encoder on mpeg4 h.264 you need modulator and up converter + power amp
Permalink Reply by Gerry Mostert on March 13, 2012 at 6:12am Thanks guys for all the input, I think we have an answer for HDMI downlink.
Now the next question 3-axis gimbal stabilisation, what else is out there except Picloc?
Our maiden flight with Skyjib on my Facebook
Permalink Reply by Gerry Mostert on March 18, 2012 at 2:15am Hi Jaan
Would one need the Teradek encoder as well as the decoder?
Permalink Reply by Jaan Kronberg on March 18, 2012 at 2:49am depends on what do you want to do. if all you need is looking at video on your laptop or ipad - no, you don't need decoder. if you want to see video on some external device (producer's monitor, plasma tv) directly without intermediate laptop - then yes, you do need a decoder.
and you can combine them - for example, use HDMI encoder cube and HD-SDI decoder (kind of transcoding pair)
Permalink Reply by Gerry Mostert on March 18, 2012 at 6:29am Thanks, fascinating.....
Permalink Reply by OG on April 13, 2012 at 5:43am Well yes & agen I keep stressing it is IP based Livestream Broadcaster pre-orders available now, shipping at the end of May for $495
A vivid memory of Cisco's would-be FlipLive streaming camera is all we've got, but thankfully there's existing devices out there like the Livestream Broadcaster to help fill that void. Priced at a whopping $495, Livestream's Broadcaster allows it to be paired with an array of shooters via HDMI and used to stream live high-def vids to any Livestream-equipped device over Ethernet, WiFi, or with a 3G / 4G USB dongle. Aside from being capable of sending out 1080i waves, the Broadcaster can also push 720p and 480i resolutions (in case you don't feel like being a bandwidth hog), while all video and audio encoding is done with H.264 and ACC, respectively. It's also worth noting that the near 500 bucks includes a three-month sub to Livestream's service, which usually costs an extra $45 per month. For now, this bright red streamer's only available to Euros and Americans, with shipping set to commence by May 31st
Permalink Reply by Jaan Kronberg on April 13, 2012 at 6:26am could you please provide some link to technical data?
for example, does this support resolution transcoding (from 480p to 720p or vise versa for example), what kind of connectivity it supports (AP and/or ad-hoc), on which bands does it work, which 4g modems does it support?
how much can i play with bitrates (what is the supported range)? does it only have hdmi input, or analog rca too?
do you have any beta testers/resellers in europe, who can share their real life experience?
thanks in advance,
jk
Permalink Reply by OG on April 13, 2012 at 6:58am Cisco camra will do this as well http://pogue.blogs.nytimes.com/2011/04/14/the-tragic-death-of-the-f...
Cameras connect to the Broadcaster via the HDMI video input (including HD 1080i, 720p, and SD 480i). The Livestream Broadcaster encodes real-time in high quality H.264 video and AAC audio at up to 2.3 Mbps. HDMI audio or line in (3.5mm jack) audio input are provided.
http://new.livestream.com/broadcast-live/livestream-broadcaster
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.111 members
137 members
1299 members
48 members
693 members
Powered by
