Hello everyone,
Hope you're doing well, greetings of the day. I'm looking to build a hoverbike with Quad propeller with 4 heavy lift motors need design, heavy lift motors, propellers, joysticks, batteries, frame, speed controllers, operating software with other equipment and accessories - all configurations are required to lift min 200Kg (Hoverbike weight + a pilot weight - Each prop should be min thrust to lift 50Kg at 50% throttle). I need to buy parts and need buildout support. Please advise, where I can buy or contact. Appreciate your support. Thanks in advance.
With warm regards,
Ravi
Your going to have issues sourcing ESC for your project but motors you have some choice you can use T-motor U15 6-8  40 inch prop 37kg thrust per motor of them love to help you with this sound like an exiting project.
http://brushlessgimbal.ca/Multi-Rotor-Products-Parts/Brushless-Moto...
Or you can use 4 of these motors 202/80 motors MP154120 50 or 60 inch prop
I do not know of ESC controller for plane more than 16S 400amps
motor cycle controller I have seen 800A-1200A 28S
