Hi everyone, I have some problem with my AMP2:
1. After I setup my new AMP2 step by step with instruction in code.google.com it running. But I found if I move any Rx stick quicker the AMP2 auto dis arm, motors still rotate, AMP2 arm led still on but cannot re arm or dis arm or do anything. I swich it off and on, it back to normal, arm and put throttle stick about 30%-40% (without propeller for safe) and hold my hexa by hand, move it forward, backward, left, right...if I move it very slowly, it ok, AMP2 auto adjust power of motors to stabilize, but if I move my hexa faster, the AMP2 auto dis arm and freeze again like when I move Rx stick quicker.
2. When I setup my AMP2 flight mode, I didn't see manual flight in flight mode list. It have many flight mode like stabilize, RTL, Loiter...but not have manual flight mode.
How do I find manual flight mode? My AMP planer version is 1.1.96
Plz help me solve those problem, thanks you very much!
Tags:
Permalink Reply by Ismail Akcoral on July 10, 2012 at 3:17am Pls check after initial setup if you changed on your radio travel adjust or endpoint settins.
Permalink Reply by OnGaKu on July 10, 2012 at 11:59pm After setup I didn't change any thing in Radio. My radio is DX6i. Is this problem because PID setting?
Permalink Reply by OnGaKu on July 11, 2012 at 12:00am Thanks you, so which normal flight mode should be? Stabilize or Acro mode?
Permalink Reply by Derek Ernewein on July 11, 2012 at 6:53am Stabilize mode will keep it level. I find this to be the best mode to start in.
It is also good to use to recover from a user-error.
Permalink Reply by OnGaKu on July 12, 2012 at 6:38am Nobody can tell me how to solve my AMP2 problem ? I still cannot flight with it :((.
Permalink Reply by Jeff Smith on July 12, 2012 at 8:25am
Permalink Reply by OnGaKu on July 18, 2012 at 1:48am My battery is full charged and when I test 2 batteries parallel the same problem. My AMP2 board power by include 5v board, not use 5v power from ESC. Few week ago when I connect all motors spin normal it's ok but when I connect reverse 3 motors (3 CW & 3 CCW) it problem.
Permalink Reply by Derek Ernewein on July 12, 2012 at 8:37am Are you saying that the APM disarms its self but the motors still spin? "auto dis arm, motors still rotate".
Can you post a video of the issue so it is easier for everyone to understand what is happening?
Have you tried watching the Tx inputs from Mission Planner while the issue happens?
Are you able to get logs off the APM with Mission Planner and post them?
Permalink Reply by OnGaKu on July 18, 2012 at 1:55am Can I connect battery when USB connected to AMP2 board for watching AMP planer while the issue happens? I never do that before, if it ok I think I can watching what appear in the AMP planer whilt the issue happens.
Permalink Reply by Jeff Smith on July 18, 2012 at 5:46am
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.692 members
51 members
186 members
1298 members
24 members
Powered by
