Help make an UGV given stock arduino mega 2560 (non ardupilot) and GPS
Hi, I am working on a project for uni where I have to make an UGV capable of waypoint navigating only.
I have a standard Arduino mega 2560, (as in an 'off the shelf' bought, non- ardupilot board) with a GPS shield and an SD shield that works currently, logging the gps data.
I only have one throttle, and one servo for steering. (k.i.s.s.)
Now given the waypoint setup in the APM, is there anyway that i can connect up two pwm controls (being steering and acceleration) and have it steer and accelerate to the next logged waypoint?
The GPS also has a compass, so heading is available.
Thanks, Justin
@Justin,
I would look at the schematic of the APM1 board and make your inputs and outputs (servos, esc, compass, gps, etc) similar to that of the APM1. The I would look at the coding that JLN has modified for the ArduRover project to get an idea of what you need to code. I think that this is a good starting point for you without having to reinvent the wheel!
TCIII
Thanks, bu Ive recently purchased the APM1 board, so ill try using that instead of the original arduino.
hi, i'm also interested for these info! i do have a 2560 mega , and i would like to use it as a quadcopter autopilot! is it possible, i mean without recoding everything ftom scratch?
