I've been struggling trying to get reliable altitude data for my quad. Whenever I try altitude hold, it'll continually rise or fall, but not hold any sort of steady altitude. In testing I've let it get to the point where it landed and where it rose over 50ft after engaging altitude hold. Here's my config:
Standard 3DR Quad kit with electronics (APM1 w/oilpan)
MB1200 XL Sonar with power supply filter installed per wiki
3DR Sonar Mount
900MHz Telemetry Kit
Turnigy 9X TX/RX
5000mAh LiPo
I'm using the BEC from one of the ESCs for my APM power. My sonar values seem very accurate when I move the quad around myself without the motors running. When the motors are running the sonar data becomes very erratic.
Here's a pic of the tuning graph when I'm moving the quad up and back down without the motors running:
Here's a pic of the same graph when the quad lifts itself to the same altitude:
It seems like the value is almost stuck around 0.4 with the motors running. The spikes you see are the correct alitude, but most of the time it's stuck at 0.4.
Any ideas on how to get alt hold working? I have a pretty stock quad, so I'm hoping someone else has already figured a way around this problem.
Tags:
Permalink Reply by Rick Eis on May 25, 2012 at 11:13pm R_Lefebvre,
I just mounted a sonar on my little quad. I want it to hold the elevation at 1 foot or so. Is this possible and if so.... can you help?
Thanks,
Rick
Permalink Reply by Wesley Chuen on May 26, 2012 at 7:22pm By looking at the APM Planner's Flight Data Tuning graph, look like it wants to follow the targetalt in 1m increment. So, the lowest would be 3 feet.
Permalink Reply by Rick Eis on May 26, 2012 at 10:41pm Hmm....when I did the CLI sonar test, it appears to start measuring pretty accurately around 22 cm. And in fact, today I was flying it indoors and I did seem to notice a difference when the sonar was engaged at just under a foot off the ground? Was I imagining things? :)
Permalink Reply by Wesley Chuen on May 26, 2012 at 11:00pm Yea, the sonar is very accurate for down to 20cm, which is the alt in the Tuning graph. My heli also able to hover at 1 foot off the ground at times as well. But when it didn't work, I looked at the Tuning graph and it tried to get the heli to follow the targetalt. And the targetalt seems to only increment in 1m.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.184 members
1290 members
51 members
11 members
182 members
Powered by
