Help with MAVProxy
I am having trouble running MAVProxy in my computer (Windows 7) to connect to my quadrotor. I have downloaded both MAVProxy and mavlink-1.0.9 and not changed anything in them.
The PATH in Environment Variables has been updated to be:
C:\Python27\;C:\Python27\Scripts\;C:\Users\...\Downloads\Mav
A command prompt has been opened, cd to directory where mavproxy.py is at, then I try to run the module by typing:
python mavproxy.py --master=COM5
I get the following error:
Traceback (most recent call last):
File "mavproxy.py", line 20, in <module>
from MAVProxy.modules.lib import textconsole
ImportError: No module named MAVProxy.modules.lib
I have tried troubleshooting the problem a lot of different ways by modifying the folder names, relocating the folder names, etc. Any help is appreciated!
  • Hi,
    I got that error too and fixed it by uncommenting in mavproxy.py:
    # allow running without installing
    sys.path.append(os.path.join(os.path.dirname(os.path.realpath(__file__)), '..'))
    I also checked out mavlink to the same parent dir as MAVProxy and did (Linux) inside the MAVProxy dir:
    dongfang@dongfang-ThinkPad-T60:~/workspace/MAVProxy$ ln -s ../mavlink/pymavlink
    dongfang@dongfang-ThinkPad-T60:~/workspace/MAVProxy$ ln -s ../mavlink/message_definitions
    This makes links to necessary stuff in mavlink. You can also just copy it if your OS does not support links well.
    Regards
    Soren
