Hello,
I am trying to create wings for a UAV project I am doing and have limited knowledge of airfoil design.  I have attached some renderings and line drawings of my design that is in progress and wanted to know if someone out there had some advice on if this would work or not.
Thanks for any help,
Will
Tags: Airfoil, UAV, design, wing
Nice looking rendering! What program are you using?
Thanks alot, I built it in Rhino and rendered in Keyshot2
yeah if you're getting it laser cut go for the wortman, its lovely
generally, the more cambered (curved) the aerofoil, the more lift its going to produce but at the cost of more drag.
And a thicker aerofoil will generally stall gently and at a higher angle of attack than a thin one.
I dont know, I guess people get paid good salaries to refine these things so choosing the perfect aerofoil is probably beyond the scope of anyone here lul
and as for the elevators or ailerons question, what do you mean ? you definitley need elevators and probably want ailerons for this plane
I'm building a wing ATM. I was planning on only ailerons(its a flying wing). Why would I also need elevators? Seems like with a flying wing since there is no tail that ailerons would suffice.
true, this guys not making a flying wing tho :3
Oh, sorry, was looking at most of his pictures which look like a flying wing. Now i see that he is planning more.
hey why don't you tell me the max. weight, desired stall speed (or landing speed) and desired cruise speed and i'll see what i can come up with.
Im hoping for this plane to be about 25 Oz. and be capable of carrying a 7 cell lipo as well as the ardupilot components inside. Speed does not need to be very high as I want this to be a slow, loiter capable vehicle that can stay up as long as possible.
Then you want a glider with long wings, and essentially flat lower wing etc...
There are two options, High ground cover (ie to photograph as much area as possible) , or loiter.
Small and long wings respectively.
okay for a 25 oz plane with a stall speed of 10 MPH (pretty slow) i came up with
for a wortman fx 60-126 wingspan 80in average chord 6.6in (area=530in^2)
at a guestimated 40 mph max speed, this wing will have a turning radius of 7.1ft lol, i dont know how long it would sustain that though!
the wing's pretty huge but then again the stall speed is small too, for a 15 mph stall, same airfoil
span = 58in average chord = 4.8in (area=279in^2)
Thanks a ton for your help Hamish. Ill take those numbers and see what I can put together, Ill let you know what I come up with.
@ william
I use XFLR5 , freeware CFD ! works great for me . a word of warning for the FX 60-126 . it has a high moment coefficient ( Cm ) = -0.144 . in plain terms it will create a forward pitching force that will increase with speed . this must be counteracted with a properly designed tail .
