  • It's possible using a Corona DIY module (CT8Z-DIY) or similar with the PPM encoder from FlyTron. I've done it and I can use the PC as 2.4G rx. I guess the FlySky 2.4 has pins that read PPM signals sowhere. Then you have to power it.
    Finally you need to generate the PPM signal. The Flytron cable does it but it's not cheap. I know you can do it with tha audio card of the pc but I have no how to get a reliable PPM signal from there.
    As said with the corona module and the Flytron USB2PPM Cable it works fine.
