How do I turn on the airspeed sensor in ardupilot mega version 2 beta using the mission planner?
the software loads ok but with the airspeed pressure sensor disabled..how do I enable it without using the arduino development tools?
right now, its not a config item you can enable yet in CLI or on GCS,
So you will need to use custom APM_Config.h and upload (with arduino) to the APM.
Here is the line you will need to add to APM_Config.h
#define AIRSPEED_SENSOR  ENABLED
Airspeed sensor from DIY Drones connected to APM, reading good voltage, but in "test" mode in Mission Planner still shows "disabled". Tried to reset,maybe it auto-detect as it should. Looks like I need to install the Arduino software and compile manually.
Have IMU, GPS, Compass, switch working. No way to enable it via CLI in Mission Planner or GCS if not auto-detected? Thanks for any help.
I have a DIY Drones MPXV5004 as well. Answer is in this link: http://diydrones.com/forum/topics/airspeed-sensor-on-apm-2012?id=70...
