How do you repeat a mission?
I've got 4 WPs set up in square pattern (and the home position also) and want my plane to repeat the pattern indefinitely (e.g. WP1->WP2->WP3->WP4->WP1->WP2...and so on).
 I tried putting a DoJump after WP4 that says go to WP1, but the plane (both physically and in HIL mode w/ X-Plane) goes to the home location and circles after WP4.  I've tried setting the repeat value at -1 as well as something > 1 with the same results.  Obviously I'm not doing something right here. Any help would be appreciated!
Thanks,
David
  • It turns out the Dummy WP is no longer needed after the DO_JUMP command. It was apparently a bug that has been squashed.
    http://diydrones.com/forum/topics/using-the-mission-planner-do-jump...
  • I can't get it to work. Here is a screen grab of my mission. The text file for the mission is also attached.
    I've tried it using a location as the last point, after DO_JUMP, as well as RETURN_TO_LAUNCH after the DO_JUMP. Both ways it continues from the the waypoint before the DO_JUMP to the waypoint after the DO_JUMP and ends the mission.
    DO_JUMP_testing.txt
    put one more waypoint after the do jump, this is because once your repeat count is 0, it will go to this point.
    so 1 > 2 > 3 >4 >dojump > 5
    this will fly 1 > 2> 3> 4> > 1 > 2> 3 >4 untill repeat = 0, > 5
