Greetings,
I've been reading through all the parameter explanations in the wiki and I have a question about the RC inputs. On the APM 2.5 board there are 8 input channels, but there are 11 RC parameters corresponding to 11 possible RC inputs. Is it possible for APM to accept input from ch 9-11? If so where and how can you make these connections? I am using the following setup:
CH 01 Ailerons
CH 02 Elevator
CH 03 Throttle
CH 04 Rudder
CH 05 Flap
CH 06 Mission Reset (RST_MISSION)
CH 07 Panel Selection for MinimOSD
CH 08 Mode Select (6 Modes)
CH 09 I would like to use this CH to enable Geofence (FENCE_CHANNEL)
CH 10 I would like to use this CH to reset to last flight mode after Geofence takeover (RST_SWITCH_CH)
CH 11
Any help understanding these parameters would be appreciated!
Nathaniel
Nathaniel,
1 ~ 11 outputs (but actually 9 doesn't exist even as an output) but only 8 inputs I'm afraid.
-Randy
Are these additional outputs (more than inputs) intended for use with say camera gimbals, tracking a location on the ground for instance? There once was a day where I would have thought having 5 or 6 channels was more than I could use! Now I'm wondering if 14 is enough! How times change!!
Is there anything in the existing Arduplane code that would allow say a PPM input on a select channel to allow you to expand the number of channels for simple switching functions, as in my example above for CH6,9,10?
If not that would be a great feature!!!!
BTW Randy thanks for your reply,
Nathaniel
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.677 members
1284 members
24 members
4 members
8 members
Powered by
