How to add a Vector3 parameter
Sorry, if this is a very elementary problem. But I haven't able to solve it for 3 straight coding days. :(
I'm developing a different type of quatrotor controller with ArduCopter V3.3-dev according to some papers. And for those controller, I need some additional parameters, some of them (e,g. inertia) are in vector form.
I've read about the article on how to add a parameters but still unable to pass the compiler:
http://dev.ardupilot.com/wiki/apmcopter-code-overview/code-overview-adding-a-new-parameter/#adding_a_parameter_to_the_main_code
Here is what I've done(for one of the parameter):
  • add parameter number k_param_ew_inertia @ Parameters.h
  • add variable declaration AP_Vector3f inertia below @ Parameters.h  (AP_Vector3 won't work as stated in the guiding page)
  • trying to get it work in Parameters.pde like:
    // @Param: EW_IXX
    // @DisplayName: Ewing inertia Ixx
    // @Description: inertia Ixx
    // @Range: 0 1000
    // @User: Advanced
    // @Param: EW_IYY
    // @DisplayName: Ewing inertia Iyy
    // @Description: inertia Iyy
    // @Range: 0 1000
    // @User: Advanced
    // @Param: EW_IZZ
    // @DisplayName: Ewing inertia Izz
    // @Description: inertia Izz
    // @Range: 0 1000
    // @User: Advanced
    GSCALAR(inertia,  "INERTIA", INERTIA_V3),
  • with defines in APM_Config.h as follows (Althought the guiding page told me to place in config.h, but config.h told me to do that in APM_Config.h)
#define IXX_DEFAULT             0.002f
#define IYY_DEFAULT             0.002f
#define IZZ_DEFAULT             0.004f
#define INERTIA_V3         Vector3f(IXX_DEFAULT,  IYY_DEFAULT,   IZZ_DEFAULT)
  • the compiler gives the error:
connot convert 'Vector3f {aka Vector3<float>}' to 'const float' in initialization
I do understand since I use the G-SCALAR it should be scalar, right? Then how should I do this right?
I've tried to initialize the AP_Vectors3 in initializers of Parameters.h like:
inertia(IXX_DEFAULT, IYY_DEFAULT, IZZ_DEFAULT),
Then compiler would give:
error: no matching function for call to 'AP_ParamV<Vector3<float>, ( ap_var_type)5u>::AP_ParamV(float, float, float)'
And call that in the constructor won't work either.
So who do I do a Vector3 parameter exactly? Is there anything I've missed or misunderstand?
The parameter part of the code is a little difficult for me and I'm not quite understand it. Again, I appreciate anyone who read this and any advice is wellcome!
