like if a turbine has 55 lb of thrust how many lb could it lift ?
Tags:
Permalink Reply by Peter Chaffe on October 9, 2011 at 12:51pm er yes, the piston engine will always be more efficient! That's why all the existing Gas turbine cars and trucks are in museums now!
Aircraft gain their advantage by using TurboFans (kind of mix of turbojet and large lower reving fan)flying at high altitude and carrying a load of passengers, then fuel per passenger per 100 miles becomes very economic looking.
Avionics, Not sure where you got 200 N from, I see the quote as 200 Lbs cargo, that would need (in turbojet terms) at least a reliable 230 Lbs or 1000 N thrust, that relates to a Mass Flow required of about 3 kg/sec.
with a stator outlet temp of 1080 k (bordering on the need for Turbine cooling) An engine that size would be more powerful that the average commercial APU... A seriously major project
Permalink Reply by avionics on October 9, 2011 at 11:20pm Reply to Peter Chaffe
Permalink Reply by alex jack on Thursday
Permalink Reply by charlie Soppelsa on October 10, 2011 at 1:22am We did this a few years ago using a Jetcat P120, the bearing will fail after 2 hrs.
Permalink Reply by alex jack on October 10, 2011 at 1:24pm if the JetCat P200-SX Turbine so bad would you recommend the Behotec B300F from http://www.altecare.com/behotec300.htm
Permalink Reply by bmarshall5253 on October 10, 2011 at 1:47pm Have you looked at the Wren turbo prop engines, they make a Helicopter model too
http://www.wrenturbines.co.uk/usa/engines/turboprop/wren-44-turboprop
http://www.wrenturbines.co.uk/usa/engines/helicopter/wren-44-helico...
I believe the turboprop produces above 50 lbs of thrust.
With the weight range you are talking about model engines are not going to make it since model aircraft are limited to 55 lbs. ( at least in US)
What are you trying to lift?
Permalink Reply by alex jack on October 10, 2011 at 9:11pm sgt ric what i do not get is why cant you just install a micro fuel pump to the turbine wouldn't the vertical problem
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1295 members
8 members
24 members
688 members
185 members
Powered by
