Tags: propellers
Permalink Reply by arashi on December 21, 2010 at 11:45am
Permalink Reply by Sanbernar on December 21, 2010 at 1:45pm after last crash I found that foam will be too weak.
Permalink Reply by Christopher Cooper on January 25, 2011 at 3:19am I'm still a noob pilot so I've broken quite a few props. To protect my props I've bolted on aluminium extensions to each arm that are slightly longer than the radius of the prop (see my attached pic). They're not as light as foam but they've saved the props on several occasions. My plan was to eventually attach a guard ring to these arms (either one per prop, or a large one around the whole quad) but this setup seems to be working fine.
Permalink Reply by Olivier Binette on February 4, 2011 at 3:23pm Hi,
I you have a quadcopter, you could make something like this: http://solsie.com/wp-content/uploads/2010/01/image8.png
You can probably make this by yourself by sculpting different materials like styrofoam. If you want something stronger, I would go with styrofoam covered by paper (or any other light fiber material) and resin.
I wish this helps you a bit!
Permalink Reply by kuxz on July 14, 2011 at 7:58pm
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1282 members
675 members
5 members
183 members
116 members
Powered by
