Hi guys I have my Arducopter fairly stable but the yaw I need help with. I am running 2.0.33, the Yaw seems to be verry springy, it takes a while to lock in but as soon as I have to move it then I get the bounce back and forth untill it settles. The Yaw PID's are standard, can someone please make a suggestion of a different PID to lock it in. Please watch the YOUTUBE video and you will see what I mean I have to constantly correct it. Once I point it to where I want to go it is fine I just want to be able for it to stay at the heading as soon as I let go of the stick. I hope I am making sense.
Regards Pete
Tags: Arducopter, Yaw
Permalink Reply by emile on August 23, 2011 at 2:58am
Permalink Reply by Peter on August 23, 2011 at 3:01am Will upgrade tonight, and poste results.
Regards Pete
Permalink Reply by Don Cramer on August 23, 2011 at 7:34pm I could have sworn I responded to this thread but geez, gone. Maybe i did not hit 'add reply'...
Anyway, first update to AC2 2.0.39 (or whatever the latest is now) and update the mission planner.
This will not fix this issue but you will be asked to do so. 2.0.39 still has the 'springy' yaw.
I played with Yaw PID's a bit a few weeks ago and asked how to possibly resolve this but never really got anywhere. I will be trying to work on this again myself in the next few days.
Permalink Reply by John Campen on January 8, 2012 at 5:23am Is there anyway to lock yaw into one position? To start off with I prefer not to have it while learning to fly
No easy way that I know of. I'm sure it could be done, but you'd have to figure out the code yourself.
Have you seen "simple" mode? Might help you.
Permalink Reply by John Campen on January 8, 2012 at 6:18pm what does simple mode actually do? Im also curious about how stabilization works if you fly indoors with no GPS. Does the stabilization need GPS or is it relying on the gyros etc?
Simple mode basically makes the yaw orientation of the copter irrelevant. Basically, you take the quad, and stand behind it with the nose facing away from you. Arm the motors. Now whenever you push "up" on the stick, it moves forward (away from you), no matter what the orientation is. Back brings it towards you. Left is left, right is right. No matter what direction it's facing. It moves orthogonal to the original setup.
Stabilization will not stay in one place, even outside with GPS. All it does is stay level. But it can drift around. So it does work indoors, but you have to prevent it hitting walls, etc.
Permalink Reply by John Campen on January 9, 2012 at 1:51am
That setting might help you learn to fly, assuming it works well. Although it could also be a crutch that prevents you learning to fly properly. I think a lot of it comes down to your attitude towards it. I would attempt to try to keep nose pointed out, and try to maintain orientation. But if you do lose it, it won't go flying into a wall because you put the wrong input.
I've never used it myself. You do need a magnetometer to make it work.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1282 members
183 members
675 members
5 members
116 members
Powered by
