I'm trying to set RSSI up for tuning on MinimOSD. I went to the guide and it states:
"Go to APM_Config.h and add: "#define RECEIVER_RSSI_PIN 6"
Note that 6 is the analog pin number where you have RSSI port connected. I have changed it to 6 as I use analog port 6. If you use a different port, replace 6 with your analog port number.
If you use APM2 or 2.5 than add: "#define CONFIG_APM_HARDWARE APM_HARDWARE_APM2" in APM_Config.h
After this you can compile and upload."
I then installed the Arduino Program, created a sketchbook, then copied my current "Arducopter" and "Libraries" folders to my Arduino Sketchbook.
I opened arducopter.pde and added these two lines to APM_Config.h
The problem is when I try to compile I get a ton of errors at the bottom and it won't compile. Here are some of them:
Attitude:506: error: 'class Parameters' has no member named 'radio_tuning'
Attitude.pde: In function 'void reset_nav_params()':
Attitude:546: error: 'class Parameters' has no member named 'waypoint_radius'
Attitude.pde: In function 'void reset_I_all()':
Attitude:561: error: 'class Parameters' has no member named 'pi_stabilize_yaw'
Attitude.pde: In function 'void reset_rate_I()':
Attitude:566: error: 'class Parameters' has no member named 'pid_rate_roll'
Attitude:567: error: 'class Parameters' has no member named 'pid_rate_pitch'
Attitude:568: error: 'class Parameters' has no member named 'pid_rate_yaw'
Attitude.pde: In function 'void reset_optflow_I()':
Attitude:573: error: 'class Parameters' has no member named 'pid_optflow_roll'
Attitude:574: error: 'class Parameters' has no member named 'pid_optflow_pitch'
Attitude.pde: In function 'void reset_wind_I()':
Attitude:584: error: 'class Parameters' has no member named 'pi_loiter_lat'
Attitude:585: error: 'class Parameters' has no member named 'pi_loiter_lon'
Attitude:587: error: 'class Parameters' has no member named 'pid_loiter_rate_lat'
Attitude:588: error: 'class Parameters' has no member named 'pid_loiter_rate_lon'
Attitude:590: error: 'class Parameters' has no member named 'pid_nav_lat'
Attitude:591: error: 'class Parameters' has no member named 'pid_nav_lon'
Attitude.pde: In function 'void reset_throttle_I()':
Attitude:597: error: 'class Parameters' has no member named 'pi_alt_hold'
Attitude:598: error: 'class Parameters' has no member named 'pid_throttle'
Attitude.pde: In function 'void reset_stability_I()':
Attitude:605: error: 'class Parameters' has no member named 'pi_stabilize_roll'
Attitude:606: error: 'class Parameters' has no member named 'pi_stabilize_pitch'
Attitude.pde: In function 'int32_t get_of_roll(int32_t)':
Attitude:781: error: 'optflow' was not declared in this scope
Attitude:789: error: 'class Parameters' has no member named 'pid_optflow_roll'
Attitude:790: error: 'class Parameters' has no member named 'pid_optflow_roll'
Attitude:791: error: 'class Parameters' has no member named 'pid_optflow_roll'
Attitude:794: error: 'class Parameters' has no member named 'pid_optflow_roll'
Attitude:806: error: 'class Parameters' has no member named 'log_bitmask'
Attitude:806: error: 'class Parameters' has no member named 'radio_tuning'
Attitude.pde: In function 'int32_t get_of_pitch(int32_t)':
Attitude:835: error: 'optflow' was not declared in this scope
Attitude:843: error: 'class Parameters' has no member named 'pid_optflow_pitch'
Attitude:844: error: 'class Parameters' has no member named 'pid_optflow_pitch'
Attitude:845: error: 'class Parameters' has no member named 'pid_optflow_pitch'
Attitude:849: error: 'class Parameters' has no member named 'pid_optflow_pitch'
Attitude:861: error: 'class Parameters' has no member named 'log_bitmask'
Attitude:861: error: 'class Parameters' has no member named 'radio_tuning'
GCS_Mavlink.pde: At global scope:
GCS_Mavlink:9: error: 'mavlink_statustext_t' does not name a type
GCS_Mavlink:19: error: expected ',' or '...' before '*' token
GCS_Mavlink:19: error: ISO C++ forbids declaration of 'prog_char_t' with no type
GCS_Mavlink:31: error: variable or field 'send_heartbeat' declared void
GCS_Mavlink:31: error: 'mavlink_channel_t' was not declared in this scope
I'm using APM2.5 with Arducopter 2.8.1
Connected to APM using USB cable on com port 6.
Have Arduino Mega2560 selected for board.
Hope someone can help me out here,
Tags:
Looks like you haven't set up Arduino right (probably libraries in the wrong place). Please follow the directions here.
Permalink Reply by Elvis on December 23, 2012 at 12:54pm Chris,
I got it to compile (see below) but my problem now is that my RSSI reading in my OSD shows 1% whether I have my Tx on or off. I followed the wiki instructions to a tee:
http://code.google.com/p/arducam-osd/wiki/Cfg_RSSI
Added line to APM_Config.h #define RECEIVER_RSSI_PIN 6
Made sure "RSSI enable Raw" was checked
Updated MinimOSD through FTDI (Config and Panel 1 tabs)
Connected Dragonlink RSSI wires to A6 on APM board.
Is the analog A6 port what I should be running my RSSI wires to? (from DL RSSI rx).
You were right (sort of). My problem was that I did follow that link - exactly, and I put my libraries in the exact same folder C:\users\Elvis\documents\arduino
This folder did not work, it was read only and I couldn't get it to un-read-only in the advanced properties tab of Win7.
Anyway, I moved the sketchbook folder to C:\program files\Arduino and it compiled without error.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1299 members
48 members
111 members
137 members
693 members
Powered by
