How to repair APM 2.5?
My APM 2.5 is spoilt recently due to short-circuit when I was trying to measure the battery voltage with my own potential divider. Currently, the APM cannot be detected by the mission planner and Arduino. Is it possible to repair it?
  • Did you ever get your board to connect?
  • not sure, the problem is still not solved yet. I haven't tried repairing it as I am not too sure which components on the board are the fuses.
  • refer to this schematic...
    http://diydrones.com/forum/topics/apm2-5-5v-vcc-schematic
    you can test the fuses with a multimeter, test for continuity/resistance across the fuse terminals...
    there should be little to no resistance...
  • what do you mean by 'cannot be detected by mission planner'?
    does the board power up? do the LEDs light up and flash?
