Are you new to drone aerial photography? Well, you’re not alone. Consumer drones are still relatively new, so you won’t find many resources on the topic. If you are planning to fly soon, whether it is for a trial flight in a small aircraft or maybe for an exploring flight in a helicopter, make sure to read these first. Hopefully these will ensure you will take off with the right equipment and the good tips to capture stunning photographs from above!
1.Choose the Right Period
The landscape can look completely different depending on the season. Spring and autumn usually offer the most colourful pictures. They are the perfect time to capture fields in flower or orange-coloured forests...
Winter is interesting if you have the chance to fly around a mountainous area. However, any plain under snow can look even more flat and monotonous.
It is also important to choose the right time of the day and, more specifically, to check the position of the sun in the sky. Because of the altitude, the risk of dazzle increases in late afternoon when the sun is low in the horizon. The sunset can offer spectacular views but with extreme contrasts between the sky and the land making it very difficult to capture. If you're flying when the sun is low, if possible choose the seat opposite to the sun.
2.The Advantages and Disadvantages of Cloudy or Sunny Weather
Of course, sunny days provide in most cases the brightest pictures and accentuate the details of the ground. However, even when the weather on the ground is perfectly clear, you can encounter haze with altitude, significantly reducing your visibility and misting over your pictures.
I find the best conditions come with a fairly cloudy day. Clouds have the advantage to naturally balance the light, and can also be a good shooting subject. Look out for funny shapes!
An overcast sky inevitably reduces the light on the ground, tarnishing the pictures, but can also provide the right conditions for dramatic photos.
Besides these,what's your ideas???
For more interesting articles or pictures,you can follow ZOOKKI on facebook.
