...Umm...How do we do this, do we essentially use the Ardupilot as the ASP and in Arduino choose ATMEGA2560 - load up the firmware as sketches and just upload...?
I think we all need details on how to perform this function.
Thanks Support
Permalink Reply by Leigh Green on July 19, 2012 at 9:50pm Jake,
thanks for the quick reply - but unfortunately that's not it, it only shows how to update the firmware of an External module by using the FTDI cable.
Problem is my MTK is onboard with the APM2.0 so how do I update the firmware of that GPS.
Can I use the APM2.0 as a pseudo ATMEGA2560 in Arduino because effectively the APM2 is a 2560 and an ATMEga32 as the Serial/USB/USBISP programmer.
I see when you import the Arduplane libraries into Arduino.cc you can see the GPS_MTK_test example sketches which define the use of fastserialport1 for obtaining raw GPS output, so I'm thinking you would just open the GPS update sketches/hexs define the appropriate fastserial and upload.
I just don't want to brick anything if this is completely wrong....:S
Permalink Reply by Jake Stew on July 19, 2012 at 11:21pm It might just be easiest to remove the daughterboard and connect to the module through the pass through header pins.
Doesn't the APM2 ship with the v1.6 firmware already on it anyways?
Permalink Reply by Leigh Green on July 20, 2012 at 8:15am I have no way of knowing as I can't FTDI the unit...so I have NFI on the MTK GPS FW V. :S
anyway it turns out my GPS is working ok it was severe weather it didn't like, but still if new firmware comes out I will need a way to jack it in and ramp it up...so no rush on this thread until then - but thx anyway.
Permalink Reply by David Baker on December 22, 2012 at 11:55am Is it possible to connect directly to the GPS using pogo pins and hook those to the FTDI? I suppose it might be best to erase the firmware from the 2560 first otherwise it is going talk to the GPS on boot up and might not allow it to work properly. Has anyone done this? I'm willing to give it a try, but it would be nice to have confirmation from someone in the know about whether or not this should work.
Thanks.
Permalink Reply by tin_tin98N on January 27, 2013 at 2:03pm I havent tested yet, just wanted to add this to This Question, as it may help others..
http://code.google.com/p/ardupilot/wiki/GenericGPS
Using arduino to load Comport leadtrought
void setup()
Serial.begin(38400); // FTDI
Serial1.begin(9600); // GPS
delay(10000);
void loop()
if (Serial.available())
Serial1.write(Serial.read());
if (Serial1.available())
Serial.write(Serial1.read());
Permalink Reply by bovonaumpan on January 28, 2013 at 10:42pm ขอยืนยันว่า E-Liquid ของเราผลิตและบรรจุขวดจากโรงงาน Dekang ไม่มีการปลอมแปลงหรือบรรจุขวดเองโดยเด็ดขาด เรายินดีให้คำแนะนำทุกท่านอย่างเป็นกันเอง บุหรี่ไฟฟ้าทำงานด้วยแบตเตอร์รี่ลิเธียมและไมโครชิพซึ่งเป็นหัวใจของระบบ ทำให้มีไฟสีแดงสว่างวาบที่ปลายมวน เสริมเข้ากับแท่งนิโคติน ภายในบรรจุนิโคตินและสารโพรไพลีนไกลคอล (PG) ในแบบรูปของเหลว มีให้เลือกตั้งแต่ไม่มีนิโคติน หรือ โลว์ – มีเดียม –ไฮ ตามความต้องการของผู้ใช้ ขณะที่อุปกรณ์ขนาดจิ๋ว (ไมโครชิพ) ที่ทำหน้าที่เปลี่ยนของเหลวให้กลายเป็นละอองหมอก และจะทำให้นิโคตินเหลวร้อนขึ้นเมื่อผู้ใช้สูบ (เปิด/ปิด อัตโนมัติเมื่อมีอากาศไหลผ่าน) และกลายเป็นไอภายในสองวินาที ให้ได้รับสารนิโคตินในเกือบจะทันที แต่ไม่มีน้ำมันดินและสารก่อมะเร็งใดๆ winningftเป็นอุปกรณ์ที่ใช้เทคโนโลยี่ที่จะสร้างความรู้สึกเช่นเดียวกับการสูบบุหรี่ ผมมีข้อมูลเล็กน้อยเกี่ยวกับแบตเตอรี่ชนิด Lithium-ion (อ่านว่า ลิเธียมไอออน) ซึ่งเชื่อว่าน่าจะเป็นชนิดที่บุหรี่ไฟฟ้าส่วนใหญ่จะใช้กัน ดังนี้ หากคุณกำลังมองหา บุหรี่ไฟฟ้า ทันสมัยที่ผลิตรสชาติที่ดีและมีการผลิตควันไอน้ำได้มากแล้วละก็ คำตอบนั้นก็คือ elips-C ซึ่งเป็นรุ่นบุหรี่ไฟฟ้าล่าสุดที่ได้รับการออกแบบมาอย่างสวยงามโดย ovale ที่ได้รับการยอมรับทั่วโลก และในรุ่นของ elips-C นี้ก็มีการปรับปรุงการไหลของอากาศให้ดียิ่งขึ้น ภายในก็มีการปรับเปลี่ยนมาใช้ Atomiser แบบใหม่อีกด้วย eGo-C ระบบใหม่ล่าสุด ที่ถูกออกแบบเพื่อการสูบอย่างมีอรรถรส เหมือนจริง ควันเยอะ และความทนทาน เหมาะสำหรับคนที่สูบบุหรี่จัด ด้วยกำลังของแบตเตอรี่ขนาดใหญ่ 650mAh ที่มากกว่า บุหรี่ไฟฟ้า รุ่นอื่นๆ eGo-C ยังสามารถถอดเปลี่ยน Atomizer head ได้เรื่อยๆ เหมือนเปลี่ยนบุหรี่ไฟฟ้าตัวใหม่ไปเลย ทำให้ประหยัดเงินกว่ารุ่นก่อนหน้านี้ไปได้หลายเท่าเลยทีเดียว
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.203 members
24 members
207 members
58 members
1355 members
Powered by
