Hello everyone,
I recently bought 4 brushless motors and 4 brushless controllers (here : http://store.jdrones.com/product_p/acesc20amp.htm). I would like to control the motors' speed with a PIC.
So, I put a 5v signal into my controller during 1ms  and a 0v one during 19ms.
I can read on the doc that I must :
1 -move the throttle stick down
2 -connect the battery pack to the esc
everything is okay
3 - a "123 beep should be emited" ---> ok
4 - a n beep tone should be emited, n beeing the number of your battery cells ---> ok
5 - After auto-test, a long beep should be emited ---> I haven't got the long beep !
my motor makes a beep, then a 2 seconds break, and then another beep, etc It means that's not the good signal...
Could anyone help me ?
Thank's a lot !
Tags: controller, esc
Maybe your ESC entering the command menu... Can you send us your manual ? I tried with arduino and made mistake... when i send numbers in loop there are command menu's commands too. so its entering the command menu and doesnt work at all.. when i sent directly run pwm command; it works.
btw here is a guy run esc with pic maybe it can help you.
http://www.designsoft.com.au/ahome/rc/PIC-ESC/ESC.html
take care.
  • X8
    X8
    130 members
