I have been using my APM1 board for a while now with APM Planner as an ArduCopter 2 mode and am now trying to get it to work as ArduPlane.
I have downloaded the firmware with in APM Planner (1.1.77 mav 0.9) with Firmware->ArduPlane 2.33.
Seems to download ok.
I connect using USB in ArduPlane mode, everything seems ok except the HUD will not respond when I move the board about.
If I go to the CLI and type test->compass the readings the values displayed look good and respond.
If I switch back to ArduCopter2 firmware the HUD it works fine.
Any ideas?
Tags:
im confused. so when does it work, and when does it not work
Permalink Reply by Peter Wlodarczyk on May 1, 2012 at 1:40pm you do have a gps plugged in? and it is getting lock?
Permalink Reply by Peter Wlodarczyk on May 1, 2012 at 3:50pm This is inside a house so no GPS lock. I've tried it with and without GPS connected, no difference.
Does it need GPS lock for gyro/compass orientation?
it needs gps lock to leave initilizing.
Permalink Reply by Peter Wlodarczyk on May 4, 2012 at 4:40am Thanks. It must be some other hardware problem that is only happening on ArduPlane. I've checked. I've checked the GPS in CLI test mode and it is ok. Must be some some other problem while initialising. So it seems not to the an APM Planner issue.
Thanks for the help though.
Permalink Reply by Mahesh M on May 30, 2012 at 11:08am I am facing the same problem
- No HUD indication on MissionPlanner-1.1.87 with APM1 + ArduPlane-2.34
- HUD indication OK with MissionPlanner-1.1.87 with APM1 + ArduCopter-2.5.4
http://diydrones.com/forum/topics/arduplane-no-attitude-indication-...
Any solutions?
Permalink Reply by Mahesh M on May 31, 2012 at 10:43am Hi Peter !!! Problem Solved !!! Your suggestion was of great help !!! I can now proceed with my plans !!! I do not have Xbee or an OSD. As you suggested I flipped the switch to "fly" position (away from the edge, toward the GPS connector). I connected APM1 hardware to APM Planner the HUD indicates motion as I move the hardware !!! Thanks again !!! Mahesh M.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.15 members
50 members
247 members
106 members
1279 members
Powered by
