Permalink Reply by Chuck on April 29, 2011 at 4:57pm I'd use (4) Jetcat P80 engines in rotating nacelles.
The rest would pretty much be fuel tanks and electronics.
Permalink Reply by Zachariah L Hanson on April 29, 2011 at 5:13pm
Permalink Reply by Max Oltersdorf on April 29, 2011 at 6:15pm
Permalink Reply by Max Oltersdorf on May 3, 2011 at 7:00pm Correction to # of channels
# of output channels needed = 8 minimum, 10 preferred
landing gear and rear door can be direct remote no need to be automatic in any way
Permalink Reply by Gerry Lichter on May 3, 2011 at 9:18pm
Permalink Reply by Max Oltersdorf on May 4, 2011 at 5:35am
Permalink Reply by Gerry Lichter on May 4, 2011 at 8:09am
Permalink Reply by Max Oltersdorf on May 4, 2011 at 9:21am
Permalink Reply by Gerry Lichter on May 4, 2011 at 12:30pm Interesting.
As far as programming, someone just rewrote the ardupilot code to include the latest APM libraries(http://diydrones.com/profiles/blogs/ardupilot-lives)
I haven't looked at the code, but a work in progress might have fewer features and therefore be easier to identify and understand the core functionalities. Similarly, some of the earliest versions of ardupilot code would likely be equally informative.
http://code.google.com/p/ardupilot/downloads/detail?name=ArduPilot1...
I'm not much of a programmer either but I can't think of a better way to learn. I'm working on a similar project attempting to add dead reckoning functionality to the code.
If you do decide to machine some molds, you may consider selling counter rotating blades as there seems to be an unmet demand. So long as you're making a solids or surfaces model, you might consider uploading it to thingiverse.
Good luck with your project.
Cheers,
Gerry
Permalink Reply by Max Oltersdorf on May 4, 2011 at 12:44pm
Permalink Reply by Max Oltersdorf on October 11, 2011 at 8:44am Please pretend for a moment that you are actually interested in purchasing a RC Pelican
Remote Controlled Vertical Take Off and Landing Aircraft
The project is to develop a scaled prototype remote controlled VTOL hybrid aircraft modeled after the Halo Pelican drop-ship. By answering the questions below you will help determine the relative importance of each feature. Please take a few minutes and answer.
How important is each of the following:
1= low importance 5= high importance Please circle your answers.
1) Similarity of appearance to Halo Pelican Drop-Ship (not exact)
1 2 3 4 5 N/A
2) VTOL ( vertical take-off and landing)
1 2 3 4 5 N/A
3) Flight stability
1 2 3 4 5 N/A
4) Low cost
1 2 3 4 5 N/A
5) Safety and Indoor safe flight
1 2 3 4 5 N/A
6) Legal to fly in the USA
1 2 3 4 5 N/A
7) Simplicity of preflight setup
1 2 3 4 5 N/A
8) Fitting into a trunk of midsize car, fully assembled
1 2 3 4 5 N/A
9) A known scale ratio (size only)
1 2 3 4 5 N/A
10) Easy for one person to fly
1 2 3 4 5 N/A
11) Inexpensive replacement parts
1 2 3 4 5 N/A
12) Durability
1 2 3 4 5 N/A
13) Easy to Assemble and maintain
1 2 3 4 5 N/A
14) Please list any other specific features which you would like to see included on possible future models. _________________________________________________
_____________________________________________________________________
____________________________________________________________________.
Thank You!
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
682 members
184 members
8 members
130 members
Powered by
