Hello i am new to all the quadcopter stuff and i am rly getting into it but i need help with Sunnysky x2212 980Kv and Afro 30A ESC the problem i have got is wiring as in what cable goes where
I have some idea but i am not sure so i upload a photo
It doesn't matter. It's three phase, so you can connect any of the three wires to any of the motor wires. The trick is, depending on where you put that specific motor, on your multicopter, you need the motor spinning either clock wise or counter clock wise.
So.... Attack it to channel 3 on your RX, and turn up the throttle. If it goes in the right direction (which can be determined by your motor plan) then great! If not, then swap any two wires.
Of course, you can start with red-to-red, etc, but really it doesn't matter.
Just make sure you know if you need clockwise or counterclockwise. Then test. If it's wrong, swap two wires. Good luck!
David > Michael PursifullFebruary 16, 2014 at 6:44am
Thank You been a big help as i was not to sure and i did not want to below thing's up
