I need some help
How can one get some help?
I am quite familiar with Quadrocopters as I have mastered flying with a KK2 board and decided to move up to the next level in the case the Ardu flight controller. Constructed a new frame etc, and then successfully flew the new copter without the GPS unit. Fitted the GPS unit and again flew successfully. The next step was to get MissionPlanner to recognise the GPS, here I unfortunately lucked out. Now the Quadrocoter will not arm, I ha reloaded the software, no luck, upgraded to MissionPlanner 3.0.1 and am still out of luck.
So my question is where to from here?
Hank
  • Hi Hank
    can you connect to the apm with the USB cable? what i read is a bit fague.
    The connected gps, does it lock? did you follow setup instructions line for line?
    cheers
    J
