I've got some stable parameters for a hobbying sk-450 frame ntm 26-28a motors and blueseries 30amp esc to share!
I did it!  I've got a perfect rock solid loiter even in 13mph gust winds!   My 2200 lipo apparently only gets me 3 minute stable flights.  Sure the motors will spin and I can fly for the next 2 minutes, but yaw, pitch and roll would drift.  The first 3 minutes are perfect!  I ordered a larger 6000ma Lipo pack.
I'm thinking if it's a calm wind I'll get @ 15 minutes,  If it's windy I'll get @ 10 minutes.
Here's the parameters I used:
ACRO_P,4.5
AHRS_YAW_P,0.2
ALT_HOLD_RTL,0
AMP_PER_VOLT,27.32
APPROACH_ALT,0
AUTO_LAND,20000
AUTO_SLEW,30
AXIS_ENABLE,0
AXIS_P,0.02
BATT_CAPACITY,2200
BATT_MONITOR,0
CAM_P_DZ,0
CAM_P_G,1
CAM_P_MAX,1900
CAM_P_MIN,1100
CAM_P_REV,1
CAM_P_TRIM,1500
CAM_R_DZ,0
CAM_R_G,1
CAM_R_MAX,1900
CAM_R_MIN,1100
CAM_R_REV,1
CAM_R_TRIM,1500
CH7_OPT,7
COMPASS_AUTODEC,0
COMPASS_DEC,-0.252
COMPASS_LEARN,1
COMPASS_OFS_X,-126.633
COMPASS_OFS_Y,37.978
COMPASS_OFS_Z,-193.855
COMPASS_USE,1
ESC,0
FLOW_ENABLE,0
FLTMODE1,0
FLTMODE2,0
FLTMODE3,6
FLTMODE4,9
FLTMODE5,0
FLTMODE6,5
FRAME,1
HLD_LAT_I,0
HLD_LAT_IMAX,3000
HLD_LAT_P,0.47
HLD_LON_I,0
HLD_LON_IMAX,3000
HLD_LON_P,0.47
IMU_PRODUCT_ID,88
INPUT_VOLTS,5
LED_MODE,9
LOG_BITMASK,0
LOG_LASTFILE,0
LOITER_LAT_D,0.4
LOITER_LAT_I,0.08
LOITER_LAT_IMAX,3000
LOITER_LAT_P,2.5
LOITER_LON_D,0.4
LOITER_LON_I,0.08
LOITER_LON_IMAX,3000
LOITER_LON_P,2.5
LOW_VOLT,9.6
MAG_ENABLE,1
MOT_TB_RATIO,1
NAV_LAT_D,0
NAV_LAT_I,0.2
NAV_LAT_IMAX,3000
NAV_LAT_P,3
NAV_LON_D,0
NAV_LON_I,0.2
NAV_LON_IMAX,3000
NAV_LON_P,3
OF_PIT_D,0.12
OF_PIT_I,3.2
OF_PIT_IMAX,400
OF_PIT_P,2.5
OF_RLL_D,0.12
OF_RLL_I,3.2
OF_RLL_IMAX,400
OF_RLL_P,2.5
RATE_PIT_D,0.004
RATE_PIT_I,0
RATE_PIT_IMAX,500
RATE_PIT_P,0.09
RATE_RLL_D,0.004
RATE_RLL_I,0
RATE_RLL_IMAX,500
RATE_RLL_P,0.09
RATE_YAW_D,0
RATE_YAW_I,0
RATE_YAW_IMAX,5000
RATE_YAW_P,0.15
RC_SPEED,490
RC1_DZ,30
RC1_MAX,1973
RC1_MIN,1173
RC1_REV,-1
RC1_TRIM,1578
RC2_DZ,30
RC2_MAX,1973
RC2_MIN,1171
RC2_REV,-1
RC2_TRIM,1574
RC3_DZ,30
RC3_MAX,2015
RC3_MIN,1114
RC3_REV,1
RC3_TRIM,1362
RC4_DZ,40
RC4_MAX,1848
RC4_MIN,1048
RC4_REV,1
RC4_TRIM,1450
RC5_DZ,0
RC5_MAX,1914
RC5_MIN,1109
RC5_REV,1
RC5_TRIM,1114
RC6_DZ,0
RC6_MAX,1913
RC6_MIN,1109
RC6_REV,1
RC6_TRIM,1113
RC7_DZ,0
RC7_MAX,1500
RC7_MIN,1499
RC7_REV,1
RC7_TRIM,1500
RC8_DZ,0
RC8_MAX,1500
RC8_MIN,1499
RC8_REV,1
RC8_TRIM,1500
RETRO_LOITER,0
RTL_LAND,1
SERIAL3_BAUD,57
SIMPLE,1
SONAR_ENABLE,1
SONAR_TYPE,1
SR0_EXT_STAT,0
SR0_EXTRA1,0
SR0_EXTRA2,0
SR0_EXTRA3,0
SR0_PARAMS,50
SR0_POSITION,0
SR0_RAW_CTRL,0
SR0_RAW_SENS,0
SR0_RC_CHAN,0
SR3_EXT_STAT,0
SR3_EXTRA1,0
SR3_EXTRA2,0
SR3_EXTRA3,0
SR3_PARAMS,0
SR3_POSITION,0
SR3_RAW_CTRL,0
SR3_RAW_SENS,0
SR3_RC_CHAN,0
STAB_D,0
STAB_D_S,0.5
STB_PIT_I,0.1
STB_PIT_IMAX,4000
STB_PIT_P,4.5
STB_RLL_I,0.1
STB_RLL_IMAX,4000
STB_RLL_P,4.5
STB_YAW_I,0.01
STB_YAW_IMAX,800
STB_YAW_P,7
SUPER_SIMPLE,0
SYSID_MYGCS,255
SYSID_SW_MREV,118
SYSID_SW_TYPE,10
SYSID_THISMAV,1
THR_ALT_I,0.007
THR_ALT_IMAX,300
THR_ALT_P,0.5
THR_FAILSAFE,0
THR_FS_ACTION,2
THR_FS_VALUE,975
THR_MAX,1000
THR_MIN,0
THR_RATE_D,0.02
THR_RATE_I,0
THR_RATE_IMAX,300
THR_RATE_P,0.2
TRIM_THROTTLE,411
TUNE,0
TUNE_HIGH,0
TUNE_LOW,0
VOLT_DIVIDER,3.56
WP_INDEX,0
WP_LOITER_RAD,10
WP_MODE,0
WP_MUST_INDEX,0
WP_RADIUS,100
WP_SPEED_MAX,600
WP_TOTAL,1
XTRK_GAIN_SC,1
Tags: NTM, frame, hobbyjing, motors
Well done for sharing that Jerry
Mine is a 650 frame but I'm sure this will be useful to many folks and there's just not enough people posting helpfull stuff/responses here
just remember its a starting point and keep an eyes on your copter.   I think if everyone posts their stable parameters and platform configs we can get a useful database going.
Hi Terry,
Any chance you could post your PID settings for the 650 Hexa? I'm having a couple of little issues with my PIDs and it would be great to compare them to somebody else's settings.
How heavy is your quad?  Thanks for the parms.  Very helpful.  Watch parm did you find gave you the best return for a good loiter.  My 2kg quad swings about 3 meters in a 10km wind. No gusts.
My quad weighs in at 968g with 2200ma lipo.   I usec the 3dr drones platform parameters as a starting point. Someone posted what parameters they changed for a 540mm platform and similar motors.  The parameter  that cleaned up loiter was located in the first param config page in mission planner.   It's late and getting ready to head to the Cape with the wife tomorrow. Taking the Wrangler along the national seashore.
The param had to do with power displacement  to thrust / throttle. The larger the motor the smaller the number.
I set mine to the lowest value in the suggested range and my oldest son and I were amazed at the rock solid loiter when I changed the flight mode from stable to loiter.   It was windy so I went through my useful available battery time in 3 minutes.   When I got to the last two minutes of available power I had to switch to stable mode to compensate for whatever motor was lagging.    I think I really shouldn't be flying during the last two minutes anyway.    A larger battery is on the way and I will be installing the attopilot voltage and current sensor.
After vacation I will post the screen shots of the parameters that helped get loiter tight.
I'm back.  I just checked to see what param I found  gave me the best return for a good loiter.  I have to say for my quad it was Angular Rate Control.  I have that set to 0.090
My motors are NTM 26-28A 1200kv
So far 3 minute stable flights.   I just ordered a larger 6000ma LiPo.  The goal is to get 15 minutes of stable flight.
I'll add dead weigh equal to another battery to see how that impacts my 15 minute flight time.  If it's > 13 minutes then I'll add another battery in parallel.
Jerry, can you post your config file? That way I can post in the repostory.
Thanks for posting this Jerry,
Brand new to the site and I just ordered the same exact parts for my first build. Really appreciate you providing a starting point that worked for you.
Dave
Cool.   Use Blue Locktite for the build.  It will keep it all together.  I use locktite for the prop mounts too. Test your setup before you mount your props.   Also be sure to configure and test failsafe... Even if you just start with the basic throttle off failsafe.  When calibrating the Escs .... I took the manual approach. It did not take long.
also when replacing the props I heat the spinner briefly with a heat gun, stick a small drill bit in the prop spinner holes hold the motor and twist.   To reuse the spinner I use some acetone, and a qtip to clean the threads.
So far with my tests a 2200ma battery is good for 5 minutes and if in wind... 3 minute stable flight. I have a 6000ma battery on the way from hobbyking.
when flying for the first time make sure you are in a large field.   I tested with no props first.
Good luck with your build!
+1 for "Use blue locktite"
I just finished re-building my quad from scratch to fix some electrical problems.
Running a test indoors, just powering up enough to see if it was taking off level. I notice a hex nut on the floor. Hmmmm.... A few second later I see a second one. Then a third. Then the quad started tilting as one of the motors started *lifting off the arm*. Turns out the nuts on the floor were coming off the quad during the test flight. The vibrations at 30% throttle shook 4 hex nuts off the bottom of my quad in less than 30 seconds of flight.
Blue Locktite - A good suggestion.
I use a lot of Nylock nuts.  Loctite is good but each time you remove/replace the nut you should reapply more Loctite.  I find Nylock nuts just keep on holding even after constant remove/replace.  Don't get me wrong, I still use Loctite on more permanent locations.
We've discussed here before how you shouldn't use Locktite on composite frames since it expands as it dries and leads to spider cracks which ends up ruining the frame.
