  • Thanks,
    So far I've clocked it at about 25 minutes (hovering only) drawing only 3500mAh of each battery.  I think I can safely stretch it to 30 minutes if not longer.  But actual flying with additional throttle and pitch and roll will be less.  I don't intend on doing much acrobatics.  Just smooth slow flying mainly for aerial photography and FPV.  I'll post more videos soon.
    regards,
    James
  • How long is your flight time with the two batteries?  Nice work!
  • What "experts" told you it wouldn't fly?  Looks like a traditional design, with the correct prop size and motors to get of the ground.  Good job.
  • It looks very stable James. Congratulations! What did you use for your booms? Looks a little like mine. I made mine out of 1/2" square aluminum tubing. I am also a newbie and have two flights on my Quad. Trying to learn more about tuning as roll, pitch, and altitude are way too sensitive. Yaw works fine. Would like to tweak it before flying again.
